Glen mate, the A/C compressor on an 84-87 is a Harrison, and in 88 they changed to a NipponDenso compressor. Its very different i assure you. Have a look at the pic of my 87 L98 and you know what your 91 compressor looked like
hi casey,
thanks for your reply and help!
so what can i do mate please?
as i have brought the a/c delete already of e-bay the one you and i replied to yesterday/today under a/c delete thread!!!
can i modify the 84-87 to suit my mount/bracket?
may be i could buy the harrison 84-87 model complete bracket and fit it to my car and then add the a/c delete pulley that o ordered of e-bay already,what do you think mate?
there must be some way i can do something/modify it?
thanks
glen
Not sure mate, that will be a question for the people that have pulled both apart and compared the two, youd think it would be doable, but exactly what youll need it hard to say, ive never considered swaping from a Harrison to a NipponDenso or vise-versa, so i dont know what is involved there with what youll need.
ok then casey, thanks for your help any way mate!
does any body know of a good cheap reliable corvette wreckers at all they can reccomend to me please?
as i want to buy a 84-87 Harrison air con bracket to modify to suit my 1991 vette to go with the a/c delete i just brought!
thnaks
glen
hi casey,
how are you!
PHIL RYDER WOULD BE THE LAST ARROAGANT DICK HEAD ON THIS EARTH THAT I WOUID EVER BYE FROM!
HE IS A THIEF,NO WAY MAN!
HAD TO MANY RUN INS WITH THAT IDOIT!
but thanks any way casey for trying to help me mate!
does any one on this forum please help me out r.e the aic con brackets!
can they be made to interchange or modify to suit one another please???
thanks
glen
hi guys,
after a bit of research off site ,here is a update if any ones interested to know or didnt know about conversion inc my self!
ok here we go then
know one currently makes a a/c delete bracket for 1991 vette as of yet!
but what you can do is buy of e-bay a 1984-87 model a/c bracket/pulley delete for around $48.00!
then jason at vette to vette has a second hand 84-87 harrison" model air con bracket for $40.00!
also to convert over is i need to add another belt tensioner and new belt!
and there you go, a a/c delete for 88-96 model complete!
but i have a 3 piece under drive pulley kit on so does that mean i need to buy a belt that is suited for a early model under drive pulkley kit then?
what about my under drive pulley kit will the early model belt fit my pulleys?
as i have to replace the belt tensioner should i buy a new one or second hand one also please?
As mentioned above the change to the Denso compressor totally changed the requirements needed to mount to engine from 87 to 88 and I guess another change in 92, hope this helps.
glen
The underdrive pulleys fit all L98's.
the belts are all the same type/no of ribs.
Lenghts vary.
You will have to buy a off the shelf belt to suit whatever final lenght is required AFTER you install the AC delete pulley.
You can not calc the lenght until finished.
No worries Glen, i cant say ive ever had any issues with him myself, but i know a couple others who have. (one of them i can see exactly why he had problems, the other guy i dont know personally)
Originally Posted by Bulldog Steve
Casey,
What is that thing you have stuck on your are filter box. Extra large air filter.
Steve
No mate, its a stock one, it even had an AC Delco filter in it. It had some gaffer tape holding it nice and tight, one of the end bits had come loose. The tape is probably what you can see.
