Lt1 steam pipe
Old Jan 11, 2007 | 08:37 PM
93-383's Avatar
93-383
Default Lt1 steam pipe
What would happen if you dont reinstall the steam pipe (crossover coolant vent on rear of heads) and plug the existing holes with a 3/8 NPT fitting. I ask becuse in the removal of my engine mine was damaged an not only does it cost $80 but ecklers is out of stock
Old Jan 11, 2007 | 11:23 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Here's a quote I found...
"The LT1 has strategically placed steam vents at the back of both cylinder heads. Since the heads are the hottest part of the engine, pockets of steam can be more easily generated there. The steam vents are connected together by a crossover vent tube at the back of the heads, which directs any steam and a small flow of coolant to the front of the engine. Without the steam vents you will have steam pockets and trapped air building up in the heads, which will cause spot overheating. This will result in blown headgaskets and other problems."
I would call a junkyard or something and try to find one. I did hear that GM discontinued them, but I was able to buy the 4 washer/gaskets needed just a couple years ago.
Old Jan 12, 2007 | 01:14 AM
VenkmanP's Avatar
VenkmanP
Just replace it with hose. If you search on camaroz28.com I think there have been a number of threads describing the correct fittings to use. I wouldn't run without it.
Old Jan 12, 2007 | 01:26 AM
BAM92's Avatar
BAM92
I think I have an extra. How's 15 bucks shipped sound. It would not be untill Monday that I can ship it though.
Old Jan 12, 2007 | 07:55 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
If anything go bigger.
Old Feb 22, 2007 | 03:36 PM
JA94vette's Avatar
JA94vette
Is there anywhere you can just get the gaskets for the cross over pipe?
Old Feb 22, 2007 | 05:09 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Standard copper or aluminum washers will work fine. That's what I use because I have zillions of them from working on diesels. They're reusable too.
Old Feb 22, 2007 | 05:25 PM
RacerX70CC's Avatar
RacerX70CC
I keep them in stock...
Old Feb 22, 2007 | 08:04 PM
Lichen's Avatar
Lichen
I paid $59 for the steam pipe,$24.70 for the seals, and $11 for the bolts.
To Lt1 steam pipe
