" small cap distributor w/built in coil "?
Old Jan 12, 2007 | 02:39 AM
sxyvet's Avatar
sxyvet
Default " small cap distributor w/built in coil "?
hi guys,
i am thinking of buying the holley stealth ram intake and getting the plenum box cut down /modifyed to fit my 1991 L98 engine!
any how i have heard that you need to fit a small cap distributor over the standanrd large cap distributor?
but what i needed to know is there any company that makes a small cap distributor but with a built in coil pack like the large standard cap/distributor?
if so what price are they?
where to buy it from?
what brand?
how many volts does it put out?
and while i am here is there any other mods that ned to be done to fit the stealth ram on, like say throttle cable,water neck ,or any other mods that need to be done?
thanks guys!
cheers
Old Jan 12, 2007 | 03:01 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
not sure on the 91, but my 87 had to get a new complete distributor with remote coil, and also installed msd 6al for my HSR buildup. Distributor: $200, MSD setup: $300
Waterneck needs to be replaced..
If you email me, i have a complete parts list w/numbers for the HSR buildup...be happy to send to you
Old Jan 12, 2007 | 03:57 PM
pablocruise's Avatar
pablocruise
There is no where on the small cap dist to mount a coil.
You will also have to get a conversion harness for the small dist.
You will need to figure out how you are going to connect the fuel lines.
The waterneck, I ended up modifying the stock one. Cut it and TIG welded it in the new direction.
It is not a plug and play system.
Larry (LD85) or Ken (slalom) should be chiming in here pretty soon.
They have it dialed in also.
Old Jan 12, 2007 | 04:25 PM
sxyvet's Avatar
sxyvet
hi there vinnie,
how are you!
thanks for your reply and advice mate!
if you could please send me the list of all the parts i need to convert it completely over that would be really great thank you kindly!
do you have some part number i may need at all also please?
so what was the performance gain like ,you got from the stealth ram upgrade?
did you find you got good all round power &,rpms?
if you can mate, you can send to,
sxy_corvette@hotmail.com
thanks very much vinnie
cheers glen
Australia
Old Jan 12, 2007 | 04:28 PM
sxyvet's Avatar
sxyvet
hi there paul,
thank you also for your reply and help/info r.e small cap distributor!
cheers
glen
To " small cap distributor w/built in coil "?
