Port Runners/Plenum??
Old Jan 13, 2007 | 04:38 AM
gregm999's Avatar
gregm999
Default Port Runners/Plenum??
I'm looking to add some extra horsepower but I don't want to modify the stock intake. I don't really care too much about upper end power, but if I can gain some upper end without losing any low end torque, I wouldn't mind doing that. Right now the car is mostly stock except for headers, true duals, and cut lid. I'm thinking of porting the runners and plenum for some extra air flow. My question to those who've done this is, first of all, will I feel any significant gain? And second of all will I lose much, if any, lower end torque?
I'm not looking to get into the 12's by building a high rpm monster, my goal is to get into the mid-low 13s, and maintain all of the lower end torque that the L98 is known for.
Old Jan 13, 2007 | 04:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I got no measurable gain from porting the plenum & runner flanges.
For quicker throttle response try bumping the TPS base idle voltage to .65Vdc.
A 160deg T-stat & fan switch will add some power as will cut-back stock AC Delco spark plugs.
Of course deleting the spare & jack will drop about .05sec off the time slip at the traps.
BTW, what is your current ET, trap speed and 60' time??
Old Jan 13, 2007 | 05:04 AM
gregm999's Avatar
gregm999
Good ideas. I'm also looking into buying an underdrive pulley kit as well as advancing the timing to 8-10 deg.
I have no idea what my current et time is since I've never taken the car to the track. However, after I do a few more mods, I will get to the track this Spring and see where I'm at.
Old Jan 13, 2007 | 05:28 AM
gregm999's Avatar
gregm999
Quick question, I am planning on getting the march underdrive pullies, but is there much of a performance difference between the steel and aluminum pullies? The aluminum ones are $100 more. Also, should I go with the power and amp series or the performance series?
Old Jan 13, 2007 | 10:47 AM
65Z01's Avatar
65Z01
I have the steel March Power & Amp series, running only the crank & alt pullies, and didn't see any gain in trap speed though the engine seemed to rev quicker in 1st gear. The overdrive alt pulley is needed to assure charging at idle.
In retrospect I think the Al pulley set would be better due to the lower rotating mass of the Al pulleys.
Old Jan 13, 2007 | 11:11 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Full 1.6 roller rockers with springs would be a good way to go.
Old Jan 14, 2007 | 03:20 AM
gregm999's Avatar
gregm999
Anyone else with experience with the Steel VS aluminum pulleys?
Old Jan 14, 2007 | 10:45 AM
wro87's Avatar
wro87
I bought a set from ASP of billet steel under drive for less than $200 for all three. The weight saving would be not much the Aluminum ones are shinny when polished up (steel can be painted).
wro87
Old Jan 17, 2007 | 12:22 AM
gregm999's Avatar
gregm999
I guess what I'd really like to know is, will I lose much low end torque if I port the runners and plenum? Also, how hard is it to install 1.6 roller rockers?
Old Jan 17, 2007 | 12:40 AM
65Z01's Avatar
65Z01
I didn't see any change in top end nor short time after porting plenum & runners so no change in torque. But doing the siamese base mod did cost a little low end but flattened the torque curve so that my shift points are not in the high 5k RPM range.
To do 1.6:1 RRs properly you need to install new valve springs. This requires holding up the valves while releasing the old springs. Some use compressed air but I use the "rope trick" to hold my valves up.
In any case it really isn't difficult; I would say a day or two max would get the job done.
On my '88 I had to grind down the drip tabs and narrow the bolt towers inside the stock valve covers. Neither was a big deal with a Dremel.
Since my valve covers were brown, it was a good opportunity to sand and paint them too.
Old Jan 17, 2007 | 12:47 AM
gregm999's Avatar
gregm999
Did you notice much of an improvement in power after you installed the RR?
Old Jan 17, 2007 | 02:15 PM
BADDUCK's Avatar
BADDUCK
Most report 10-15 HP increase with full rollers. Remember it will oil better and run quieter and that's a real bonus.
To Port Runners/Plenum??
