Does your Holley AFPR hold pressure?
Old Jan 13, 2007 | 07:23 PM
Wheelman's Avatar
Wheelman
Default Does your Holley AFPR hold pressure?
Mine won't for some reason. Brand new and it wont hold pressure and wont adjust higher than about 34psi either. I triple checked the install and the spring and cap are definately installed correctly. Replaced with the stock regulator and cap assembly and it primes to about 42psi and holds just fine. WTF?
Old Jan 13, 2007 | 09:16 PM
viii's Avatar
viii
my holley holds pressure fine. if you are losing pressure, could be something else. On my 85, it was my pulsation dampner (after swapping lots of parts) .
Old Jan 13, 2007 | 09:36 PM
Road Agent's Avatar
Road Agent
Go with the stock.
Old Jan 13, 2007 | 11:29 PM
RRT vette's Avatar
RRT vette
My Holley held pressure fine until I found a leak a few weeks back. Not sure if the Holley is the problem or not. I don't see fuel in the AFPR vac.
Old Jan 13, 2007 | 11:40 PM
96GS#007's Avatar
96GS#007
Mine held fine.....until the diaphram in it went bad
Old Jan 14, 2007 | 09:02 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Mine holds fine and i can easliy crank it up to 50 lbs. Maybe one more look is required.
Old Jan 14, 2007 | 08:00 PM
ericcer's Avatar
ericcer
mine too
To Does your Holley AFPR hold pressure?
