Optima Cold Start Reliability
Now this normally wouldn't be a big deal, just pop the hood and jump start the car, right? Well the hood's frozen shut, and being that the car sits in the shade all day, it's not likely to defrost anytime before tomorrow(we're supposed to have a high of 41).
Has anyone else had problems with their Optima in freezing conditions? I thought that the sealed gel-cell type batteries were supposed to not have problems in cold weather. I also had absolutely no problems like this 2 or 3 months ago when it sat for 4 days during our last snow.
.One thing I noticed when I bougth the red top is the cold cranking amps is a little lower than other batteries I have owned. But I had no issue through last Chicago winter with the car starting.
I like the leak proof design but they really have issues with spotty reliability.
If you have some jumper cables, attach one cable end to the post terminal and the other end to a good ground like the alternator bracket. If the battery has any voltage at all, you should at least see an interior light go on.
There have been a number of threads about failing Optima Red Top batteries over the last year. Some seem to las about a year, some only a couple of months.
A buddy put a Red Top in his ZR-1 las April and it lasted two months. He had it replaced under warranty and the replacement lasted about 6 months. He now has an AC Delco battery in the car.
Given the number of reports of Optima failures, it's possible that there was a bad batch of Red Tops that got shipped all around the country.
Any decent battery with a full charge should be able to handle the temps we have been seeing. My daily driver 99 Silverado sits outside and with the 12 to 15 degree overnight temps down here in the Olympia area, the truck has not failed to start. It has a AC Delco Professional battery that is 5 years old.
There is also a chance that you could have a drain of some sort that is discharging the battery. Underhood lights, console light, or even the lights in the sunvisors could be left on.
Once you get the car started, take it to a reputable shop and have the charging system checked out. The test will show if the battery can hold a charge or if the alternator is providing the necessary current to charge the battery. The fact that the voltmeter is showing 14+ volts doesn't necessiarly mean that the battery is taking and holding a charge.
We pushed it out of it's icy graves, and pulled Craig's 92 up next to it to jump. We hooked up the jumper cables, and it took no less than 15 minutes of charging to get the car to the point where it would start.
During this time, I took a closer look at the car. The hood was covered with a 3-4" layer of snow and ice, and a spot in the very center of the hood was a completely bare dry spot. I investigated it more, and there was frozen condensation on the inside of the hood in the same spot. What sat under that spot? My MAF Sensor.
I replaced the sensor in October, and both of the relays in December. I guess the burnoff circuit kept drawing power all 5 days, and the cold didn't help. Does anyone have any experience with the burnoff relay supplying power to their MAF when the car's off?
Thanks.
maybe that's why they recommend you change the relays when u change the maf?? If it sticks, I would ohm the maf and see if it's resistance is really low in comparison to a rebuilt or a friend's unit. but be careful you only ohm the burnoff circuit and not the air measuring circuit, or it's toast anyway.
