Ported MAF
Old Jan 15, 2007 | 10:21 AM
Achilles's Avatar
Achilles
Default Ported MAF
I was wondering what advantage vs. disadvantage to cutting out the heat fins in the MAF. And what are the fins in there for?
Old Jan 15, 2007 | 11:12 AM
tjwong's Avatar
tjwong
I have not seen any definitive gains when "gutting" a sensor. It isn't worth the problems unless your engine demands more flow. The screens and vanes inside serve to create a laminar air flow so that the sensor can more accurately measure the incoming air flow.
The sensor is a flow measurement element and in the normal process industry it normally needs X upstream and X downstream lengths of straight run before the measuring element. In a automotive application sometimes you can't get those demensions. So that is why GM designed the sensor with straightening vanes to give the sensor a more accurate reading of the air flow. Typically in a process application a flow sensor needs at least 5 pipe diameters of upstream lenght or for example a 6" pipe would be 18" upstream from the sensor and 2x diamters or 12" downstream.
Old Jan 15, 2007 | 12:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed, unless your engine demands close to 750cfm of air flow you will not likely see any benefit from descreening & gutting the MAF. And the stock TB will not flow to that level anyway.
The fins were put in there as heat sinks due to some testing done in Death Valley.
I've installed a 52mm TB and gutted the MAF, so my engine is now ready for the "buildup". That said I did NOT see any change in trap speed from the mod.
Old Jan 15, 2007 | 01:08 PM
vader86's Avatar
vader86
Dont mess with the heat sink fins, its too risky. You could end up buying a new sensor if you mess with them and screw it up.
Old Jan 15, 2007 | 01:32 PM
Race Prepared's Avatar
Race Prepared
Old Jan 15, 2007 | 06:36 PM
Achilles's Avatar
Achilles
Ok, advice taken.
Old Jan 15, 2007 | 08:42 PM
All2kool's Avatar
All2kool
And if you've priced a new Bosch MAF you'll notice they're around $745.00 new.
To Ported MAF
