Need o2 sensor?
Old Jan 15, 2007 | 03:52 PM
bigbob1's Avatar
bigbob1
Default Need o2 sensor?
I already did a search on this but couldn't really find anything. I am getting ready to put on a set of hedman long tube headers on my 85. I am also putting on new intake at the same time. I am planning on getting a new chip burned because I am getting rid of the all the emmissions crap. Do I need the o2 sesor or is this something I can delete? I will also be running with no convertor. Any help would be greatly appreciated.
Old Jan 15, 2007 | 03:59 PM
85vet's Avatar
85vet
Cruise-In V Veteran
The O2 is essential for idle and general driving for computer control. It can also be a good tuning tool for WOT runs - at drag strip.
I have no emissions but run an O2.
Old Jan 15, 2007 | 04:19 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Get the heated O2 sensor and check vaders site, complete info on hedder installs and O2 installation.
Old Jan 15, 2007 | 04:20 PM
vader86's Avatar
vader86
The O2 sensor is one of the 2 most essential sensors on the car.
Delete it and your gas mileage will go in the toilet.
Old Jan 15, 2007 | 04:27 PM
bigbob1's Avatar
bigbob1
Where is the current o2 sensor located? Will I need to weld on a new bung for it. Or should I just get the collectors with it already in.
Old Jan 15, 2007 | 05:23 PM
RRT vette's Avatar
RRT vette
Your stock location for the O2 sensor is in the down pipe, in the front y-pipe, on the driverside. Look down on the left exhaust manifold and you will see it. It has one purple wire. A heated O2 sensor is a good idea if adding longtubes. They are usually wires (signal, 12v, and ground).
Old Jan 15, 2007 | 05:24 PM
RRT vette's Avatar
RRT vette
Do a search for "heated O2 sensor" and it will pull up threads where others tied in for the 12v. Many different locations.
Old Jan 15, 2007 | 07:37 PM
vader86's Avatar
vader86
Yes, and Yes.
To Need o2 sensor?
