Security Alarm
Old Oct 2, 2001 | 02:12 PM
Camvette's Avatar
Camvette
Default Security Alarm
I have a '85 coupe and didn't realize that I do not know how to turn off the alarm when activated. Can someone please clue me in? :rolleyes: :crazy:
Old Oct 2, 2001 | 02:15 PM
scorp508's Avatar
scorp508
Default Re: Security Alarm (Camvette)
The alarm in the early C4s is activated when you lock the doors using the power locks. The alarm is the deactivated when you open the doors with the door key. There is a small microswitch in each door that gets tripped when using the key to deactivate it. If some day you find that the driver's side door no longer deactivates the alarm, it is because that switch has failed. The passenger side one will probably still work since the driver's side gets 90% of the use over time.
If you were to reach in the window, slide the lock open, then open the door, the alarm would go off. It will also go off if the hatch is opened.
Also, you can deactivate it by drilling a hole in the battery. ;)
Old Oct 2, 2001 | 09:53 PM
moffitt's Avatar
moffitt
And the switch is a real bear to replace!
Unless you have very small and talented hands!
Old Oct 2, 2001 | 10:50 PM
Jsailor24's Avatar
Jsailor24
Default Re: Security Alarm (moffitt)
I have activated it before and the ignitoion doesnt dis-arm it, the pass door doesnt either-- hope the drivers side never fails. :(
To Security Alarm
