Quick Part Swap Questions
Old Jan 19, 2007 | 02:35 PM
SDS Photography's Avatar
SDS Photography
Default Quick Part Swap Questions
I have found an 84 and I have a 89 that needs a few parts. I need headlight motors and a digital dash. Both work on the 84 but I am concerned that neither will work on my car.
Anyone know?
Old Jan 19, 2007 | 02:55 PM
Bob CTS's Avatar
Bob CTS
The 84 has a different appearance to the dash for sure, but I can not answer if they can be swapped.
I think the 89 has a different headlight motor than the 84.
I could be wrong others will know for sure.
Old Jan 19, 2007 | 03:16 PM
5pinball's Avatar
5pinball
84 cluster may or may not work. you will def. have to change odometer motors. not hard. cc. may not work. if price cheap enough on cluster try it. if it doesnt work you can always sellit on forum. hdlites willprobably work, but you may have to fudge conectrs. again, if cheap enough.
Old Jan 19, 2007 | 05:02 PM
champs65's Avatar
champs65
I'm pretty sure the cluster will work and plug in properly. As you know and has been posted, the readout will look different, as well as having a lower redline.
Old Jan 19, 2007 | 06:51 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
I know a `84 digi will work in a `88.
Old Jan 19, 2007 | 08:39 PM
-=Jeff=-'s Avatar
-=Jeff=-
my friend has an 89 dash in his 84
To Quick Part Swap Questions
