Was wondering any one could help out.
I have a 96" LT-4..
I was stopped at a light and whne i started to drive it was a huge dip in the raod and was impossible to avoid it. I drove over it at about 2-3 mph. It sounded like the car bottomed out. it was a loud bang type noise. Ever scince that day it started making a ticking noise from 2,000-5,000 Rpms, in all gears. I Checked the oil and all my fluids and they were all fine.about three weeks later i drove my car one day to check it and it started to feel like i was gonna stall out the rpms kept dropping and rising. And now my car wont start . Any ideas on what could be wrong??? Please email me at Faisal@impfirm.com
Is the oil pan damaged? It did not happen to get pushed into the oil pickup tube inside the pan? I am not familiar with the 96 underside, just a thought.
The rpm dropping and rising could result from restricted exhaust. You may have crushed the pipes or fractured the internals of one or both of the catalytic converters. I ran over a curb once in a '55 original small block and pinched the tail pipe. Car would not run.
Or you may have depressed the oil pan slightly, as mentioned, so it touches the oil pump. I've had dented oil pans click and it was certainly rpm related but of course not gear related. The depression in the oil pan was so slight that it was very difficult to see.
I don't think you are going to get any driveshaft to turn "easily" by hand , in neutral or otherwise. Think about grabbing it by hand, and trying to get the wheels to turn! Not gonna be easy.
I don't think you blew your engine. RPMs wouldn't fluctuate like you describe to kill the engine (lots of rotating mass). I know nothing about LT4's, but an RPM fluctuation and then failure to start sounds more like a coincidence, perhaps due to not being driven frequently. JMHO.
However, a crushed exhaust is an interesting possibility
I have a 96" LT-4..
First things first, have you looked under the car ? It may be obvious what is wrong with it. I would check the oil pan first. That's the only thing I can think of that would cause a ticking sound but what you call a tick for all I know could be an exhaust leak. Check the oil pan and the exhaust for any signs of damage. When you say it won't start what do you mean ? Will it not turn over ? IS the engine turning over and just not starting ? We can get you through this but lets eliminate the obvious first. What exactly happens when you try to start it ??
I tried to turn my Drive shaft... It wouldn't turn and offered alot of resistance....
DOES THIS MEAN MY ENGINE IS BLOWN????
Please Any Ideas would be helpful
What do you mean you tried to turn the driveshaft ? Did you have both rear wheels off the ground and the car out of gear ? I am not in any way trying to insult you, but I can't assume what you do or do not know. Even with it in the air and both wheels off the ground the driveshaft will be a bitch to turn.
When i tryed to start it, it wont turn over it just clicks once and then nothing...... i will get under the car this week.
My buddy brong a pri bar to try to turn it... but i didnt have the wheels off the ground... so maybe thats why i am not to sure...
i am kinda new to this working on my car my self.. but would love to try to figure this out... and i appreiciate all the help.....
if there is any books you guys can suggest to get more familiar with my c4 please let me know.....
At this point go to the basics, but it might be best if you purchase the Factory Service Manual for your year.
Battery voltage = what is it?
Starter = solenoid bad possibly?
Others will add to the list
As for turning the engine over, you do not have to have the wheels off the ground, just have the car in neutral and a ratchet or breaker bar with the correct size socket on the balancer if you can get to it, again not familiar with the LT series.
Normally I would encourage a person to do his own work but from what I can tell from your posts is that you may be in way over your head. You need to find someone who really knows cars to check your car over. I applaude you for wanting to do the work yourself but you need to start with a good running car and do some basics like oil changes etc. just to get to know the car better. Once you feel comfortable doing small maintenance work then you can move on to bigger things.
As you have been told already, any damage you may have done will be easily spotted if you look under the car, once you find the damage if there is any, then you need to get someone with experience to assess the damage.
Bob
Check your battery and basics.
The original problem ? Could be anything...
Did the original ticking sound happen in neutral or while in gear? And while at idle not moving?
For one thing...from all of the stuff you've been saying about what you hear with your engine, don't worry about the drive-shaft for now.
Your drive-shaft is linked directly to your rear wheels. If you do not have your rear wheels off the ground, you shouldn't be able to turn it...and if you were able to turn it, your car would move/roll forward or back. Your transmission being in neutral will "disconnect" the engine from the drive-shaft. So, if you can not get it to turn over, the problem would most-likely have to be with something in front of the transmission (ie - the engine).
Check these things first as others have stated:
First and foremost, check that oil pan. Next, crushed exhaust.
________________________________________ _____________________
I MEANT TO SAY I TRIED TO TURN THE CRANK SHAFT! With a breaker bar on the crankshaft bolt and it would not move. shouldn't the crank turn if the engine is NOT locked?
Is there anything else that would keep the crank from turning by hand?
ANY IDEAS????????????
ok, don't take this wrong, but you need to find a good service center. You know just enough about cars/engines to be dangerious. I don't believe you have a problem which is all that serious, but you might... and learning about advanced diags is not a good idea at this time.
For example, did you put the car in neutral before trying to turn the crank with a breaker bar? If not, it won't budge.
I suggest Tony's over in Gaithersburg. I would at least call him. He has a great rep... it's just that he doesn't work on maintenance issues, just restorations and such. but he might take on a bigger issue.
however, a good, local shop should be able to guide you.
A question - did you remove the plugs? that will tell you if there is anything in the cylinders. My 92 had a problem with the fuel pressure regulator, and it dumped fuel all inside the manifold, in turn, filling #6 and 8 cylinders with fuel. I removed plugs, gas poured out.
my guess? something got knocked loose, but nothing major happened. A big dip at 2-3mph shouldn't hurt jack.
