95 parking brake ??
Old Jan 20, 2007 | 06:10 AM
95 blue pig's Avatar
95 blue pig
Default 95 parking brake ??
On my 95 auto vette ,if I apply the P.brake, than lower the lever so I can get out of the car. Than when I restart the car to leave the brake seems to release automaticly. A mechanic said it cant release by its self ,its A rachet action that pulls A cable tight.. But I never release mine by hand and no brake lite comes on after restarting and leaving.I think it is automatic release,RIGHT!!
Old Jan 20, 2007 | 06:16 AM
VenkmanP's Avatar
VenkmanP
No. Have any rear pads left?
Old Jan 20, 2007 | 07:15 PM
aminnich's Avatar
aminnich
If the handle moves up and down with no resistance and the button NOT pushed in your E-brake is still engaged. There is NO automatic release and give your mechanic a raise.
Old Jan 20, 2007 | 10:01 PM
jimgoss's Avatar
jimgoss
Cruising
Default Yet another question
The parking brake handle of my 88 has lost its "ratchet" action. The brake works but will not engage in the on position. Is this a handle issue or something in the rear break?
Old Jan 20, 2007 | 10:07 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Its in the handle assembly
And to the OP Have your mechanic check your rear pads I would tell you to do it yourself but anyone who thinks C4s had an automatic parking brake release cant be trusted to do this kind of thing
Old Jan 20, 2007 | 10:08 PM
aminnich's Avatar
aminnich
Sounds like it is in the handle, not the back.
Old Jan 21, 2007 | 12:05 AM
lefoy84's Avatar
lefoy84
Hijacking the man's thread is poor form!
Old Jan 22, 2007 | 06:38 AM
95 blue pig
the p.brake lever works fine. I understand how the rachet thing works. If I apply p.brake ,but need to get out of car,I can lower the handle and the remains engaged. If I turn the key on the brake lite stays on. But if I start the car and put it in drive there is no brake light on the car rolls easily.If I than pull the brake lever I get resistance right from the beginning of the pull. Last time I checked rear pads they were good,but I will look again. And yes the p.brake holds pretty well.
Old Jan 22, 2007 | 06:50 AM
RRT vette's Avatar
RRT vette
When you apply the park brake, lift the lever and it will click..more than one time. The brake light on the DIC should come on. To release the park brake, Pull up on the lever and it should not click and will move loosely up and down. While in the up position, press the "button" on the end of the lever in and let the lever down. The light on the DIC should go out.
As stated there is no "automatic" release on any year C4.
To 95 parking brake ??
