air cond. flashing
Old Jan 20, 2007 | 02:47 PM
prodadiv's Avatar
prodadiv
Default air cond. flashing
My 1990 air conditioner is flashing when I first start the car.
Has anyone had this happen? If so how do you fix or adjust?
Old Jan 20, 2007 | 03:51 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
When you say flashing, I take it you have a sight glass on it?
Old Jan 20, 2007 | 04:38 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Reading between the lines, I think you mean the LED on Climate Control Panel on the dash is flashing.
If so, this means an air conditioning system fault has been detected and a code has been stored in the module.
Page 1C1-2 of the 1990 Service Manual covers the retrevial of the codes.
To do this, push and hold the fan up and down arrows at the same time for about 5-6 seconds. The LCD will show "-00". Push "Auto" and the LCD will show any fault codes that are stored.
While in the diagnostic mode, it is possible to show a number of other system parameters also, but the one you want is "-00".
Fault Codes
00 Not used
01 Temp. Door Motor Circuit Fault
02 Temp. Door Motor Circuit Fault
03 Ambient Sensor Open
04 Ambient Sensor Short
05 In-Car Temp Sensor Open
06 In-Car Temp Sensor Short
07 Solar Load Sensor Open
08 Solar Load Sensor Short
09 Low Freon Detected
10 UART Failure
Old Jan 22, 2007 | 10:05 AM
prodadiv's Avatar
prodadiv
Great feedback, I appreciate it
Old Jan 23, 2007 | 11:51 AM
jghmczo6's Avatar
jghmczo6
Check the owners manual also, I have done this and it works; pull fuses #1 and #17 wait 20-30 seconds then replace and start the car, should
clear. When it did not clear I was low on freon. Hope this helps.
To air cond. flashing
