Mufflers
Old Oct 3, 2001 | 12:50 PM
Jim D's Avatar
Jim D
Default Mufflers
I just received my new Borla mufflers any suggestions on how to cut my exhaust pipes straight to install new mufflers, I have a sawsall Thanks Jim
Old Oct 3, 2001 | 02:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Mufflers (Jim D)
I would also replace the stock Y-pipe with a hi-flow unit. But that's not your choice, so this should work.
Cut the muffler off just at the Y-pipe end. Then carefully slit along the length of muffler pipe that remains on the Y-pipe (a cordless Dremel works great here). Then pry that slit section open and remove it from the end of the Y-pipe.
Old Oct 3, 2001 | 05:26 PM
into01000101's Avatar
into01000101
Default Re: Mufflers (65Z01)
Well, he can still use an aftermarket rear pipe, even if he didn't opt for the 2 1/2" system. The mail order guys should have a direct replacement y for under $100.00. If you use the old y-pipe, you are going to have a bit of a time aligning those tips, it's tough enough with the complete system.
Good luck!
To Mufflers
