C4 Window adjustments ?????
Old Jan 23, 2007 | 06:59 PM
vjpat's Avatar
vjpat
6th Gear
Default C4 Window adjustments ?????
Hi Folks :
I have an 87 Vette that I put new weatherstriping on last winter . I discovered that I need to make some small adjustments to the windows
to accomadate these new rubbers . However , I need a source of instruction . Any suggestions ??
Old Jan 23, 2007 | 09:14 PM
Greg Gore's Avatar
Greg Gore
Several of us including myself have written extensively with detailed adjustment procedure. Just do a search mostly in C4 tech and lots of info should turn up. This will be a good time to look at the plastic window guide for wear (most will need replacement) and the window regulator if your 87 has the ribbon type which is failure prone. A search will turn up lots on this too. C4 window adjustment is fairly straightforward, not hard to do at all.
