85tpi
Old Jan 24, 2007 | 08:57 AM
dallasknight's Avatar
dallasknight
Default 85tpi
can anyone tell me why my 85 vette with the a tpi would back firing when i get down on it it's doing it in the pipes not out the end i have to change the iat and will do that with weekend but right now it's unpluged the car runs fine but i want to know what is causing the backfiring
Old Jan 24, 2007 | 10:05 AM
rick lambert's Avatar
rick lambert
I'd check the timing first, then I might do a compression test to check the condition of the valve train, which brings us to are the lifters adjusted properly? alot of things can cause a back fire, including having a plug wire on the wrong plug. Did this just start happening? have you done any work on it lately?
Old Jan 24, 2007 | 10:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Pat, i would like to buy a period, and I don't mean Vanna's
Your backfiring may be due to the fact that the ECM is seeing a very cold intake temp (due to your unplugged IAT) and is adding more fuel than you need.
Old Jan 24, 2007 | 10:25 AM
dallasknight
thanks guys
To 85tpi
