Explain BLM's
Old Jan 24, 2007 | 10:00 AM
Lichen's Avatar
Lichen
Default Explain BLM's
Put my '93 on the scanner yesterday to double-check that the new heated O2 sensor was working (it was). Everything else seemed to be in the correct range too, except the BLM's. As I understand, they should be about 128. One of mine read 130-135 and the other side read 117-122. Can someone explain to me what this means?
Old Jan 24, 2007 | 10:13 AM
rick lambert's Avatar
rick lambert
BLMs=block learn mode, it's actually the long term fuel trim (long term in computer lingo equals a few seconds). 128 is a target, in other words most cars differ some and vary up or down. I can't explain one side from the other, seems like my l98 only has one side, one 02. But, I don't think your readings are out of whack, might be just a difference in the 02s.
Old Jan 24, 2007 | 12:59 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
BLM / INT numbers can be thought of as fuel multipliers, with 128 being the target. Readings higher than 128 indicate that the ECM is picking up a lean condition and is trying to correct it by adding more fuel. Numbers in the 130-135 range would be a little more fuel added, 150-160 would be a LOT more fuel added. Readings lower than 128 indicate that the ECM is picking up a rich condition and is trying to correct it by taking away fuel. Numbers in the 126-122 range would be a smaller amount of fuel taken away, 118-108 would be a larger amount taken away.
I am not as familiar with split BLMs like that since my car only has one O2 sensor. If one sensor is brand new and the other is fairly old, readings might be affected. But it is interesting that one side is reading a bit lean while the other side shows rich. This thread might help: http://forums.corvetteforum.com/show...ght=split+blms As posted by TJ, a small exhaust leak could definitely cause the split BLM issue.
Old Jan 24, 2007 | 02:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Clearly one side is running richer, try swapping O2 sensors.
If the problem doesn't follow the sensor swap, look for a leak at the exhaust header gasket.
You could pull the spark plugs to see if a cylinder is misfiring.
Old Jan 24, 2007 | 03:09 PM
Lichen's Avatar
Lichen
The O2 sensor idea makes sense. Last week, we switched the left one to the right (the right one ended up being dead), and installed a new one on the left. I need to blow out the carbon that accumulated from the bad sensor. I'll try that and re-scan. Thanks guys.
Old Jan 24, 2007 | 04:55 PM
bobmic93's Avatar
bobmic93
Those are good #s.
Old Jan 25, 2007 | 02:28 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Actually those numbers aren't bad at all. They will swing from bank to bank quite a bit especially if the car has a cam
Old Jan 25, 2007 | 02:35 PM
Lichen's Avatar
Lichen
It has a Hotcam. I fell much better now. Thanks, all.
To Explain BLM's
