Hypertech and LT1/LT4 temperature sensors.
Also, there is supposed to be DTC codes thrown when that ECT sensor get's out of tolerance, I had none. Also leading me to believe that it's not off far enough to set a code, but off far enough to make sitting in the car on a hot summer day unbearable.
Reprogramming fans or changing to a cooler thermostat will fix neither problem, it will be at best a band-aid.
Which I think, after all the verbiage, is what you said.
The cooling system mechanically now is 100% but you're right, the supporting electronics are what is broken. Or at least not operating the way they should.
Both the analog temperature gauge and the digital temperature gauge get their readings from the same temp sensor in the engine bay. I don't believe that the analog temp gauge is accurately calibrated at the factory - it's more of a ball park estimate of the actual temp. The digital gauge, on the other hand, shows the actual reading from the temp sensor as interpreted by the ECM.
I would also tend to give more credibility to the digital gauge than the analog. It sounds as if the digital gauge and the ECM correspond on their measurements, indicating the temp displayed on the digital gauge is in fact the temp measured by the ECM. The Analog gauge is also driven by the ECM, but sounds as though the calibration on the sweep is off.
Open your service manual and you will see that the ECM reads the ECT mounted in the wter pump and the analog gauge gets it's information from the head sensor.
The sensor in the head is a one wire = Analog gauge
The sensor in the water pump is a two wire = Digital gauge and ECM fan control, among other things.
If I remember correctly, with the key on:
1) Shorting the wire to the engine block should make the analog gauge go to the bottom of the scale.
2) Leaving the wire hang open, should make the analog gauge go full scale.
This would test the gauge but not the sensor.
Tom Piper
Tom Piper
Tom Piper
We have also seen a lot of members report the analog going to 250-260, the ECT being bad and reporting temps too low could explain this situation.
Coming right off the bat with "this is normal" isn't helping solve the problem, in fact it may be harming some without the full story.
Honestly, when it warms up outside I'm going to get a new sensor and compare the old to new and see if there is a difference. Also compare them to the resistance chart vs. temperature listed in the service manual.
Yeah, the analog gauge and sensor for it are a complete stand alone system. You could effectively take the sensor and gauge out and no other system in the car would be affected.
I have not observed a vast difference between my analog and digital temp gauges. I have a '96 LT4 (current mileage around 28,000) that's had the water pump replaced. Shortly after the pump was replaced, the car ran hot. I burped the system several times, air bubbles came out each time, and after I was finished the temps were normal (fans came on at 230 on the digital temp gauge and off around 215ish). Even when running hot, the digital and analog gauges roughly matched each other. In my case, running hot was a result of air in the system and not a faulty sensor.
For my particular car, the gauges that don't match well are the digital and analog oil temp gauges. The analog oil temp gauge reads low and barely moves during operation. In my case, the digital oil temp gauge appears to read correctly, but I've never deep-dived the situation to verify.
I have a 396, with a 160 degree t-stat, Dewitt's radiator, Elec WP, and the PCM is programmed to turn the fans on earlier. My car stays at 170 -175 degrees according to the digital sensor, while the analog sensor usually sits right on the 185 mark.
Then when the fans try to kick on at 219, neither will come on since the fans are in series and the opened fan coil blocks the circuit...
At 228 the fans are told to go to high speed which puts them in parallel, so now the good fan runs and the bad fan still doesn't come on...
One fan will only provide marginal cooling....
So are you sure both fans come on or did just one come on at 228 (more or less 228=230)...
You wouldn't be the first to have a bad fan......or maybe a bad fan relay(there are three involved)...
Again, good luck on finding your problem..
I replaced both sensors on my 95 along with a bunch of other stuff when I redid my heads. My digitall and analog gauges read very close to the same temp.
LT4BUD, very good thought, I remember checking mine when I first got my service manual but should check again as there's no code to tell you one fan isn't working.
Cold_B, for whatever reason my temps act the exact same way now with the 160 and fan change. The only thing I can guess is one or both gauges become VERY unlinear at higher temperatures.
I want to see if I can make my car comfortable the way GM designed it, with the way it was sitting in the car on a hot summer day in traffic was unbearable. Most of the time like Wilson, my car would gurgle after shutting it down, god forbid I shut it down near 230 on the digital, I usually ran the ac until it got a bit lower. I swore off the changes for as long as I could take it because everyone here said, everything was normal. This all after a new radiator, t-stat, flushing the system and bleeding it 'till I bled. The heat from my car just got to be too much to take so I did the nasty (t-stat, fan reprogram) and worried no longer.
Something had to be wrong with that situation, I can't see GM making a car get that hot before turning a simple fan on. Anyone that says all this is normal is off their rocker, or at least doesn't understand what kind of heat can emanate from these things at high temps. NONE of my other GM vehicles exhibit those symptoms and one of them even has a 195 t-stat in it.
It'll be interesting to troubleshoot this, but I can tell you I'm not gonna waste a lot of time on it because the 160 t-stat and fan change works so well it's almost a shame to mess with it in the name of curiosity. I also have three other things I want to do to it this summer.
Are you starting to see what I'm getting at? I think we have some LT1 owners with ECT sensors that going off the chart causing way too high temperatures.
First, you have to know what temperature the thermostat is and then run the vehicle on the open road on a very cool day (hopefully, 50 degrees or less) without the A/C on.
After the engine is thoroughly up to operating temperature keeping a steady speed of about 50 mph or greater (but not pulling hard), look at the digital display.
With a 180 degree thermostat, the LT1/LT4 will read about 194 degrees.
With a 160 degree thermostat, the LT1/LT4 will read about 178 degrees.
Because this is a reverse flow cooling system with the thermostat on the inlet side of the engine and the CTS on the outlet side of the engine, the digital display will read the thermostat reading plus the amount of heat picked up by the coolant going through the engine.
If your digital display is in the "ball-park" of those readings, there is nothing wrong with it.
The CTS in my '92 is original and it has been consistent for 15 years.
But, I have had three Hypertech 160 degree thermostats and two of them gradually increased in their opening temperature until they were about 180 degree -- replace them and the temps came right down to what it should be.
Tom Piper
Tom Piper
I’m thankful to say that this is my operating parameters also.
There are not many days that I don’t run the A/C in Orlando due to the warm temps and to keep the moisture down in the car. Due to this, there is usually a fan running which keeps me between 195 and 205 while driving. In slow traffic for long time it will start to creep up but will usually turn on the aux fan switch and start the second fan at about 215 or so.
Been cold this week in Florida in morning (40s) and am using the heat (no A/C) and as long as I am moving, I stay 195-205. You can bet if I stop for a while with no fans running the temps will start going up but will kick a fan on before 220 and problem solved.
My analog gauge is pretty close to the digital, all stock, 180* stat and 2 year old radiator which is slightly thicker (5/8") than the original one that I took out. Have not re-programmed anything, just control second fan manually when I need to.
