I'm getting an occasional "random missfire' code and am pretty sure it's the wires, as I'm also getting a fair amount of radio static.
Does anybody here have a recommendation for quality high performance wires? I'm looking for a tailored set that I don't have to cut or assemble.
Thanks!
I like either the Taylor or the Accel Extreme 9000 series wires. Another choice are the Taylor Thundervolt 8.2mm series wires, these are a bit harder to fit into the stock looms but also work very well.
Now here's something interesting about Magnecor wires...
The reason Magnecor Race Wires are so flexible is that the insulating jackets are made entirely of high-temperature aerospace silicone rubber, which by nature is strong and extremely flexible, and, unlike all other performance wires, can safely be installed into the original 7mm size spark plug wire retainers despite the larger 8.5mm (Magnecor KV85) cable size.
If this is true these might be an alternative to the MSD 8.5mm. They're actually claiming you can stuff their 8.5mm wires into a 7mm clip, so certainly they should fit into 8mm clips with no modification, right?
I'd have to see it to believe it, anyone have a pic?? Pryderei???
I've had Magnacores for almost 4 years and have had no problems. I ordered the ones for the LT1 and they installed as easy (very difficult) as any other wire.
