Fuel Pressure Gauge..
Old Feb 2, 2007 | 04:36 PM
devilfish's Avatar
devilfish
Default Fuel Pressure Gauge..
..that i can mount inside the car. What unit fit the tpi/lt1 fuelrail connection? A link to a summit or jegs item would be appreciated.
thanks
Old Feb 3, 2007 | 02:09 AM
Mo_Bandy's Avatar
Mo_Bandy
I use the autometer electrical unit that actually has a pressure sensor that I mounted on the schrader valve with the pressure valve removed.
If you choose to go with a mechanical version, you need to order the transducer which you fill with antifreeze on the cabin side of the transducer. The fittings are AN-4's ....
You would need to order the meter , transducer ,and a length of AN-4 braided hose.
If I recall the electrical version is complete with the meter.
Feel free to PM or email me if you like...
Mo
Old Feb 3, 2007 | 10:42 AM
devilfish's Avatar
devilfish
you got pm..
To Fuel Pressure Gauge..
