Code clearing
Old Oct 4, 2001 | 09:52 PM
tsquare's Avatar
tsquare
Default Code clearing
Does the ecm store codes when they pop up.If so how can they be cleared from the ecm?
Old Oct 4, 2001 | 09:55 PM
moffitt's Avatar
moffitt
Default Re: Code clearing (tsquare)
Unhook the batter for a minute or two, then reconnect it. The car may idle funny for a few minutes, it has to go through the idle learn process again.
Old Oct 4, 2001 | 10:35 PM
Larrym96815's Avatar
Larrym96815
Default Re: Code clearing (moffitt)
If you would pull the ECM fuse would it clear the codes without losing all of the radio and clock settings?
Larry
Old Oct 4, 2001 | 10:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Code clearing (Larry Mackey)
On my '88 there is an orange wire with an in-line connector near the battery that powers the ECM. Open that connector and it only resets the ECM; the fuse should work too but the wire is easier.
To Code clearing
