882 bulbs
Old Feb 3, 2007 | 08:11 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 882 bulbs
I have an 86 vette and the bulb burned out behind the information panel. This is where you can switch between seeing your oil pressure or coolant temp. or you can switch between water temp and mileage. I might have the order wrong. The bulbs that are behind the panel that light up when you turn the headlights on are the ones im talking about. Can I replace these bulbs with 882 bulbs. The same bulbs i replaced in the cluster?
Old Feb 3, 2007 | 11:51 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I think you can...check this link out...
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Old Feb 4, 2007 | 01:41 AM
86PACER's Avatar
86PACER
[/QUOTE]
To 882 bulbs
