Question for the C4 Tech crew
Old Feb 4, 2007 | 11:30 PM
RRT vette's Avatar
RRT vette
Default Question for the C4 Tech crew
I would like you guys to list me out things on a Corvette or any vehicle than you have seen or know that will make a stock engine/stock chip run rich. The component and why. Open and closed loop.
I am going to start fresh and check over all things again. Thank you
Old Feb 4, 2007 | 11:40 PM
kize's Avatar
kize
I'll start-
Leaking fuel injectors
Bad O2 sensors
Old Feb 5, 2007 | 02:03 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
bad coolant temp sensor or unplugged/bad connecton on same
when its bad or unplugged/short the pcm will read by default way low (something like 15deg) and will really pour the fuel to it.
Old Feb 5, 2007 | 08:39 AM
rick lambert's Avatar
rick lambert
Well, those are good suggestions,,but we know your fuel components are new..injectors, fuel pressure regulator and 02 sensor...
CTS..yes
bad ECM, but you've tried two.
connections and circuitry to all fuel and air components, 02 sensor, MAF sensor, ECM etc.
vacumn leaks...and sometimes thoughs are hell to find, they can seem good at lower engine temps. but show there ugly heads when the engine warms up or just the opposite.
exhaust leaks.
valve train.
and sometimes you can ohm sensors til you're blue in the face and get good readings...but they need to be ohmed both hot and cold for a more accurate assesment which is difficult to do,or wiggle/twist the wires and you may find you have a bad circuit, one of the reasons we use scanners.
I'll also throw in weak spark.
Old Feb 5, 2007 | 09:00 AM
vader86's Avatar
vader86
MAF, but usually throws code
CTS
TPS problems, also typically throws something
bad regulator, injectors
O2
vac leaks
spark being too far gone
last thing is ECM
all i can think of at the moment
Old Feb 5, 2007 | 09:28 AM
RRT vette's Avatar
RRT vette
These are some of the things I can think of.
1. Leaky injectors (CSV where applicable)
2. Weak spark
3. Bad oxygen sensor....sensor/wiring/connection
4. Bad CTS....sensor/wiring/connection
5. Bad MAF sensor....sensor/wiring/connection/leaks in air duct
6. Faulty AIR....introducing air into the manifolds in closed loop
7. Bad MAT....sensor/wiring/connection
8. Bad EGR....valve/solenoid/wiring/connection
9. Vacuum leaks....introducing atmospheric air
10. Too much fuel pressure
11. EECS system....solenoid wiring/connection/vacuum leak or plug
12. Exhaust leak before the oxygen sensor giving false readings.
13. Alternator wiring
14. Bad TPS....sensor/wiring/connection/adjustment
15. Bad ECM
Just looking for other places.
Old Feb 5, 2007 | 02:48 PM
RRT vette's Avatar
RRT vette
I had ohm tested the CTS a good while back and it tested fine when cold. I didn't test it when hot though. The connector clip is broken, but I get no code. I am trying to think of things that will make the engine run rich in open and closed loop. There are components on these cars that only work/send signal after the engine is a certain temp, when timers go off, and at certain speeds or throttle positions.
I ordered a new CTS and connector and will change it out. I hate to throw parts at it, but $15 for the sensor and $5 for the connector are not bad and stand the best chance of being the culprit since it's rich from start to shutdown. I'm having a hell of a time installing my cable on this laptop.
Old Feb 5, 2007 | 04:18 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
If you haven't been able to do a real time scan yet, stop trying to troubleshoot until you get the cable / laptop connection figured out - that will be your biggest asset, that's what you should focus on. The scan data should be able to give you a much better idea of what is happening.
But yes - the CTS should be fixed, so I wouldn't call $20 for a new CTS and connector "throwing money at it"
Old Feb 5, 2007 | 04:36 PM
Vetracr's Avatar
Vetracr
On early year C4's with only one O2 sensor you can have one of two problems. You can have leaking injector on non O2 sensor bank that O2 sensor won't pick up. Conversely you can have clogged injector on O2 bank causing ECM to richen both sides. You can also have a leaking cold start injector.
Larry
Old Feb 5, 2007 | 07:45 PM
rick lambert
All good advice, and this will get you TTT. The CSV can and will cause a problem....if the gasket allows leaking. So will others, the gasket or shaft at the TB. You've elimated things like injectors etc. But think about fuel pressure also....you maybe going the wrong direction here...just a thought, because fuel atomization can be a problem also!!!!!!
Also forget about the EGR, Vader has explained this, and if memory serves correct...you don't have a functional EGR?
Don't forget about the cannister too!
Here's something else, forget about open and closed loop, there's timers, heat, etc. that come into play, and IF you went to third gen, you'd get alot more understanding about that.Good Luck Dusty
Old Feb 5, 2007 | 08:18 PM
mseven's Avatar
mseven
looks like most has been covered .................but, when you say rich, how rich? secondly, did you look at a scanner (stock tune)before, as in day one before anything was ever touched? the stock tune/chips I have seen can be+or-10 approx. in BLM numbers.
Old Feb 5, 2007 | 08:36 PM
RRT vette's Avatar
RRT vette
I got home this evening after work and check a few more things. I used the timing light to check for spark on all 8 wires...and all 8 showed good. I listened with my stethoscope at the injectors. I could hear all of them ticking the same. I set my minimal idle again as when I put the stock chip in, it changed it a little. I plugged off three vacuum lines that go to the EECS. TB line, rear vac line, and tank line. Fuel pressure at 39 psi idle and TPS at .56v.
I looked at the CTS with a light and yes the clip that firmly connects the connector is broken off and I could even wiggle it...it's loose. Put about 1/2 can of Seafoam and Heet in the tank and about 10 gal of 93 octane (highest here).
While I waited for it to warm up after starting it cold, I could tell there was a miss. But after it warmed up it idled smooth. This Corvette runs like crap. Even power braking it wouldn't turn the tires. Pitiful.
Old Feb 5, 2007 | 08:37 PM
RRT vette's Avatar
RRT vette
Yeah, not throwing money at if for something that needs replacing anyway, I agree. I also agree that I need to scan it again before much else. I am having a time getting the drivers installed on my laptop. I have a thread in scan and tune.
Old Feb 5, 2007 | 08:41 PM
RRT vette's Avatar
RRT vette
Larry
8 22# stock injectors and CSV cleaned and serviced by Rich in the last few weeks. I actually put the injectors in the rail and connected the CSV with the fuel lines connected and pressureized the rail. No visual leaks, but pressure did drop. No gas in the FPR vac and pinching off the feed line did help either....and no external leaks.
Old Feb 5, 2007 | 08:44 PM
RRT vette's Avatar
RRT vette
TB gasket just replaced with the injector swap, same for the plenum and runner gaskets. The TB shaft seems firm and the plates close all the way. I'm using stock fuel pressure with stock injectors as of now. EGR and solenoid are still on the car and the pipe is removed. Thanks Rick
Old Feb 5, 2007 | 08:46 PM
85RIT's Avatar
85RIT
RRT, I wish I could help you out but you are methodically troubleshooting as I would and as you helped me too.
I agree with the not throwing money at it. Right now I am between a short in a wire and a bad ECM with my left injectors not firing.
I would hate to buy a new ECM when it is just a wire.
Good luck!
Old Feb 5, 2007 | 08:51 PM
RRT vette's Avatar
RRT vette
I have a catalytic converter in my garage ready for install as the previous owner told me the cat is hollow. But want to run a scan before install. The rich smell has gone down a good bit but still stinky even at full warm up. I ran a scan with the 24# Accels in with a stock chip. BLM's always dropped to 108. Haven't ran a scan with the stock injectors yet, but you would think after all I have done with this car as far as troubleshooting...that going back to stock would help.
Oh, I have capped off the AIR pipe that feeds the exhaust manifolds. Haven't completely troubleshot the AIR system yet, but figured I could stop air from entering the exhaust in case it never switched to the cat.
To Question for the C4 Tech crew
Old Feb 5, 2007 | 08:52 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
When I answered your earlier post I should have elaborated a bit more on the MAF connection. Mine felt and looked tight but the engine would stop running rich when I held the plug off to one side a bit. I took the connection and cleaned both the male/female sides, then I used a tiny pick to tighten terminals on the female side, then I just very slightly bent the male terminals. The connection went back together much tighter and my rich condition disappeared. BTW, this condition threw no codes. I hope you find it soon, this sort of thing is maddening.
Old Feb 5, 2007 | 08:55 PM
RRT vette's Avatar
RRT vette
Good luck!
I understand the frustration completely. If I had more time this problem would have been fixed. Hope you find the answer soon...keep at it.
Old Feb 5, 2007 | 08:59 PM
RRT vette's Avatar
RRT vette
Thanks for the information. I need to go back over all the connections of these various items. The loose CTS connector, is a possible problem. I will take a close look at the MAF connector. Last scan I did, the MAF was ~8.9 g/sec at 850 RPM which is normal. The coolant temp on the scan correlated with the temp on the dash. As, I know the ECM gets it's readings from the CTS and the dash gets it's from the guage temp sender in the right head.
