Antenna grounding question.
Old Feb 5, 2007 | 11:38 PM
Trog's Avatar
Trog
Default Antenna grounding question.
Years ago I bought the "upgrade" from MAD or someone like that and installed it per the "limited" directions. I currently have the rear facia off & before I re-install it I wanted to clean up & route the extra antenna ground leads again.
My question has to do w/ actually attaching the far ends of the new leads to the frame. The origional instructions didn't have you do that, however, the 3 factory ground straps DO connect to the frame. One to the side, one to the antenna mount & the last to an upper screw where the rear facia mounts. That would give you the steel strip around the top of the facia as additional ground.
Any thoughts, knowledge on if I should go ahead & terminate the "upgrade" ground wires around various points on the rear subframe? Will it help FM radio reception at all? I'm in the sticks so FM is pretty limited.
TIA
Old Feb 6, 2007 | 12:43 AM
85 500 horse's Avatar
85 500 horse
If the instructions advise to do it, I'd do it. I don't see why it would be there if it wasn't needed.
Old Feb 6, 2007 | 01:29 AM
Trog's Avatar
Trog
Actually, the instructions did NOT advise either way, (that I can remember anyway.). I'm sure if it had said to, I would have...
Old Feb 6, 2007 | 03:43 AM
VenkmanP's Avatar
VenkmanP
TIA
I suspect that you bought a ground plane kit. Not an electrical grounding kit.
I don't know whether electrically grounding the ground plane wires would be harmful to it's purpose, but it definitely isn't normal. The factory ground plane wires in the later cars are not electrically connected to anything but the antenna.
OTOH, if you actually bought grounding straps, then by all means get them connected to a ground.
Old Feb 6, 2007 | 01:23 PM
Trog's Avatar
Trog
Hey Vis,
I believe you are correct in that this is a "grounding plane" upgrade.
To Antenna grounding question.
