Best 96 brake pad replacement ???
Oct 5, 2001 | 10:50 AM
Time for a front pad replacement. Have new Stock rotors.
Which, in your opinion, is the best pad for heavy/daily street use with the occasional trip to the track???? (gotta be squeekless!!)
Oct 5, 2001 | 05:35 PM
Re: Best 96 brake pad replacement ??? (ivan)
Stay away from the PEFORMANCE FRICTION line. They squeel like stuck pigs and are as dusty as my grandmothers' underwear. Stick with the stock pads from the General.
Oct 5, 2001 | 06:14 PM
Re: Best 96 brake pad replacement ??? (C44ever)
NAPA ceramics. :yesnod:
Oct 5, 2001 | 07:16 PM
I've got PF and they do stop very well.. but yes, they are some squealers!
Oct 5, 2001 | 08:15 PM
NAPA CERAMICS NO NOISE, NO DUST. :yesnod: :yesnod:
Oct 5, 2001 | 08:36 PM
Cruise-In III Veteran
Re: Best 96 brake pad replacement ??? (shepsvettes)
Do the NAPA pads come with the retainer clips??
Oct 6, 2001 | 10:35 PM
Re: Best 96 brake pad replacement ??? (Springer's 95)
hawk hps street pads are my fav, no noise awesome stopping, they work with a glowing red rotor but at the same time are not too spendy & last quite awhile, i've tried about every pad made on various cars...no one can turn me from the hawks for dual purpose...awesome pad
Oct 6, 2001 | 10:57 PM
Shep: Any problems installing those ceramics? Anything different from a standard set of pads? Thanks in advance :cheers:
Oct 7, 2001 | 02:27 PM
Alright!!
So, sounds like the NAPA Ceramix pads will probably bee the ones I go With.... Gotta find a Canadian distributor....
Has anybody used the Hawk HPS's??
Ivan
Oct 8, 2001 | 05:30 AM
keep asking about hawk before you buy you'll find other oppinions similar to mine. also best brakes in ontario {sic?} canada is a distributor for them
Oct 10, 2001 | 12:09 PM
.... here we go..... ordered the hawk hps's fror the front. if they work out ok, will do the back afterwards.
One last quick question, Does my 1996 Collectors Edition LT4 have the same brakes as every other 96???? is only one pad listed, but i thought that the brakes were upgraded???
Ivan
Oct 10, 2001 | 10:41 PM
Same pads on all 96's.
Tom Melton
82 CE
86 Z51 Coupe
Oct 10, 2001 | 11:53 PM
I've been using PFC Z-rated pads for 4 years and never had a problem with squeeling. They dust a bit more than the stock pads, but they work great for street/track use.
Oct 11, 2001 | 06:41 PM
Thanks for all the good ideas... hawks have been ordered, wil install next week....
Oct 12, 2001 | 09:31 AM
Don't the 13" rotors require different pads? I have the J55 brakes.
Oct 12, 2001 | 09:50 AM
I just looked and I have the J55 Brakes as well..... Does anybody know????
Oct 12, 2001 | 10:11 AM
All 95 and 96's come with the big brake package standard.. they use the same pads.
Oct 12, 2001 | 01:48 PM
Thanks for all of the good info........
Oct 12, 2001 | 02:14 PM
Cruise-In II Veteran
MarkBychowski
I agree, irun teh PFZ pads and never get any sqeal
Oct 12, 2001 | 02:18 PM
Re: Best 96 brake pad replacement ??? (tommelton)
OK, I'm confused. I'm in the process of accumulating part to upgrade to GS Brakes.
According to Jeff Kopp Web Pages, there are separate part numbers for J55 and GS calipers. I understand the cosmetic difference in the GS but there are also separate part numbers for the respective pads.
Looks like rotors are all the same.
Which way is it:confused:
[Modified by John Row, 12:22 PM 10/12/2001]
