Best 96 brake pad replacement ???
Old Oct 12, 2001 | 05:57 PM
ericcer's Avatar
ericcer
Default Re: Best 96 brake pad replacement ??? (John Row)
I thought that the regular brakes are 12" in the fronts and the J55 are 13". How can the pads be the same?
Old Oct 12, 2001 | 07:54 PM
LT-IV's Avatar
LT-IV
Default Re: Best 96 brake pad replacement ??? (ericcer)
I will take a stab at this one.
All 95 & 96's had 13" brakes. (front)
There are different rotor part numbers because the G.S./Collector rotor has a coating on it to prevent rust.
The G.S./Collector rotors are painted black and have a little more "meat" in them that is supposed to prevent flexing. That (and the cool looks) is what you get when you upgrade.
:yesnod:
Hope this helps.
[Modified by LT-IV, 5:55 PM 10/12/2001]
Old Oct 13, 2001 | 10:17 PM
importeater's Avatar
importeater
pads are the same becuase they use the same caliper, just a different rotor & knuckle to mount on. also sounds like you made a good move on the hawks ivan, most everyone i've sold them to has been just thrilled with the performance / cash ratio.
Old Oct 15, 2001 | 12:06 PM
18carfan's Avatar
18carfan
Cruise-In II Veteran
OK, I'm confused. I'm in the process of accumulating part to upgrade to GS Brakes.
According to Jeff Kopp Web Pages, there are separate part numbers for J55 and GS calipers. I understand the cosmetic difference in the GS but there are also separate part numbers for the respective pads.
The physical dimensions are the same and you could use one in place of the other however the GS pads are a different material. I do not know the exact difference unfortunately but I will see if I can find out. -Jeff
Old Oct 20, 2001 | 08:09 PM
ivan's Avatar
ivan
Default Re: Best 96 brake pad replacement ??? (UPDATE)
Got the Hawks installed. Perfect for my application!! Enhanced braking (noticable diffference than before). No squeels. Unusual that the surface of the Hawk pad is slightly smaller than stock.
As for stock pads... I put new stock pads on about 40000km and two years ago. So i figured they would be close to the end of there life, i was wrong. Over half of the compound was remaining.
Anyhoo, they are on, i'm happy and it is one thing off the 'to do' for the Corvette!!!
Ivan
PS. The one time i actually read the GM Shop manual before doing the job, it was wrong. It said all 96's came with 12" directional castings (rotors) which are interchangeable from left to right. So i did't pay much attention to my dealer acquired rotors. I finished the install on the RHS, and when doing the LHS, i noticed that it had RH stamped on the inside of the rotor. SO it set me back 15 minutes to change the RH rotor. But all is good now. PPS my brake rotors are also 13" diameter......
