Let me start off by saying I know 215 - 220 Coolant Temp is normal, so with that said here is my question. I just recently changed my water pump (due to weep hole seepage) along with upper and lower rad hoses. Prior to the change the temp on the digital guage would read 189 - 196 in traffic and would, like it is designed to do at a stop run up to 228 and the fan would come on and bring it back down to 205, even in 100 degree weather. Now temps stay at 210 - 219 even while driving in 40 degree weather. I have burped the system, but the FSM speaks of two bleed screws, one on thermostat housing (which I have found) and one on the the Throtle Body, I can not find this one. My car is currently in the garage cooling down with the front in the air hoping the air will work its way to the thermostat bleed screw and I will burp the system again. Am I missing something?
One other note, I did put a new Coolant Temp sensor in the Water pump as the old one had broken from the plastic and I kept having to push it back in. Could my old CTS have been sending false reading in the first place which led me to believe I was running cooler that I actually was? I know 210 - 219 is normal so I am not overly worried, just looking for some feedback. Thanks
Your 96 only has one bleed screw on the t-stat housing. Should have drilled one tiny hole in the t-stat before you installed it and your air worries would have been history. Now we'll hear the bandwagon jerks spout off about a hole cooling too much, or whatever, one tiny hole won't change jack as far as the characteristics of the t-stat are concerned.
I haven't had to bleed my system at all using a small hole in the flange.
BTW, yes I think your old CTS if we must call it that, the manual calls it a ECT sensor, was probably reading low. I'm fearing this is going to become a normal thing as time goes on. Yet we'll see the bandwagon jumpers again tell all the LT1 owners how normal it is to melt down sitting in your car. There is a age issue happening here and spouting off that everything is normal without all the facts if counterproductive to our hobby.
I fished the old ECT from the out of the shed and did an Ohlm test and for the current temp in my garage it had a correct resistance. I guess I will have to burp the system again till I get all of the air out as I have read that any air in the closed system will cause the temp to be higher, is this true?
Your higher temp problem is more likely linked to the new temp sensor rather than trapped air. Air will eventually bleed itself into the higher positioned reservoir, so I would not be concerned with trying to bleed air. You only replaced two items: pump and sensor. Obviously, the pump is working, and the temps with the new sensor are more within the operating range when compared to the old sensor.
If your fans are activating at the programmed temps, and the coolant loses heat with the added air flow, all seems normal.
Make sure the coolant level in the overflow bottle is higher when hot when compared to the level when cold. This proves that the system is operating as a closed system: expanded coolant is forced into the overflow bottle when heated, and siphoned back into the cooling system during cool-down.
OK, yes the primary fan are comming on at 228 and the temp drops to about 210 - 213 fairly quickly. Yes the overflow level is higher when running and just after shut off and goes back to normal cold level after everything cools down.
I know the normal operating temps are in the 205 - 220 range and I am not overly concerned about that, I just was not sure at to why the temp change difference now vs than.
My old ECT sensor was broken at the plactic colar on the sensor itself and that is whay I changes it, that may account for the temp difference now as the old ECT may have been good but with the plactic colar broken may have caused it to read lower that it realy was.
No major problems the highest I have seen since the change is 230. My fan came on at 228 (also checked with a Actron Scan tool) and temp went to 230 and than slid down to 213 with fan on. Thanks for responses
After reading that link and seeing that most new cars come with a 195 stat I think I will check my stat to make sure it is not a 195.
Wow, dejavue (or however you say it). Just saw a very similiar post in the general section. Same advise, get it to op temp (t/stat open and coolant circulating) and bleed it again.
ps--I am going to the parts 4sale section next, do you have a post on this over there too?
The tstat, whether it be 160, 180, 195 does not enter into the cooling equation once it is open. If the temp is running in the low 200s, and the tstat is of a lower degree, it is essentially just an open pipe in the system.
