c4 Rear brake upgrade
Old Feb 7, 2007 | 06:51 PM
jsconiers's Avatar
jsconiers
Cruising
Default c4 Rear brake upgrade
I saw in the sticky that there are c5 adapters. Does this count for the rear as well? and if so does any one sale the rear adapters only. I'm assuming I can then buy C5 rear brakes off the forum, ebay or the junk yard and just bolt them on. Is this correct? I'm also under the impression that I might need to change my wheel if the wheel is too small.
Old Feb 7, 2007 | 10:14 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What year is your car.
Old Feb 7, 2007 | 11:12 PM
GulfCoastEagle's Avatar
GulfCoastEagle
It won't work. The caliper mounting bracket is different with a different bolt pattern. Plus the C5 uses a drum in the rotor for the parking brake. It would take a lot of re-engineering, probabaly why no one makes such a bracket.
Old Feb 7, 2007 | 11:22 PM
jsconiers's Avatar
jsconiers
Cruising
Default ok what about c6...
If c5 won't work how about c6.....it's a 84 corvette with a dana 36
Old Feb 8, 2007 | 02:13 AM
BAM92's Avatar
BAM92
Baer makes a plus 2 upgrade for the rear that uses a 13 inch 2 piece rotor instead of 12 inch 1 piece stock rotor and spaces the stock caliper out accordingly. It is pricey though.
Old Feb 8, 2007 | 02:51 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
His car is a 84, which also utilizes a drum parking brake. So the 84-87 cars are the closest to getting a C5 caliper mounted on the rear. The issue becomes is it really worth making a bracket that doesn't improve braking performance by much.
To c4 Rear brake upgrade
