Hooker Headers
Old Feb 8, 2007 | 11:22 AM
ubnpast's Avatar
ubnpast
Default Hooker Headers
Im looking around at headers, has anyone had experience with hooker super comp's?
Will these bolt right on to me 96 lt4, and will emmissions be kept? http://www.holley.com/2151HKR.asp
Does anyone reccommend them?
Also, does the long tube keep the cats?
Old Feb 8, 2007 | 11:24 AM
ubnpast's Avatar
ubnpast
Here is what the ad says:
Footnotes:
48: Fits 6 speed ZF transmissions and standard 5 speed.
92: This header is equipped with a fitting to accept the stock oxygen sensor.
117: Reducers with oxygen sensor on 1980 and later models are available for purchase in our ebay store.
212: Does not fit with AFR angle plug heads.
Port Shape: Same as Port
P/S Yes
P/B Yes
A/C 9
Manual on Column No
Manual on Floor Yes
Automatic on Column Yes
Automatic on Floor Yes
Old Feb 8, 2007 | 11:56 AM
STL94LT1's Avatar
STL94LT1
You can't use the stock cats with long tube headers. You'll have to go with a set of bullet cats.
Old Feb 8, 2007 | 12:35 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I would get coated headers. Those 18 gauge painted headers will get hot as hell. If you have to pass emissions dual hi-flow cats with a custom y would work well.
Old Feb 8, 2007 | 02:42 PM
C409's Avatar
C409
Default Hooker
I have a set on my 87 and I love 'em...the cats had to go....mine came from Summit and at the time coated headers were the only ones available.....the 87 has one O2s on the left bank..the headers came with one bung in the #7 cyl tube....I welded another bung in the collector and use a heated O2s so it reads the whole left side of the engine instead of just one cylinder . Install was easy from under the car and they have BIG tubes @ 1 3/4" . I had a custom dual 2 1/2" exhaust made with Flowmaster 50 series mufflers.....I don't have testing here so cats weren't considered.. ENJOY
Old Feb 8, 2007 | 08:43 PM
ubnpast's Avatar
ubnpast
Well I have a 96, and I dont think there is a y. I would def. get the ceramic coated ones, I was looking at these http://cgi.ebay.com/ebaymotors/84-96...QQcmdZViewItem
So all I need is bullet cats (or no cats), but all other emmission stuff will bolt on and not be effected?
Old Feb 8, 2007 | 08:52 PM
BADDUCK's Avatar
BADDUCK
I have an '89 so I have y-pipe on the brain. Yeah, those are the right ones for the air hookups. I guess you could duals with or without cats.
Old Feb 8, 2007 | 09:51 PM
tntcorvette's Avatar
tntcorvette
you should check with the LT1, LT4 crowd to see if there are spark plug clearance issues and what to do about the air pump hook up and relocating the o2 sensors.
I see alot of LTx cars using the tpis headers or the exotic muscle units.
Old Feb 8, 2007 | 10:28 PM
A95Y's Avatar
A95Y
If it has an AIR pump like I think it does, you are going to have to mock up an AIR tube fitting on each header, like I did. If you buy ceramic and do this, you are going to have to get them coated again. I painted mine and will check the temperatures against the ceramic coated shorties I have on now, once installed. The hole front half of the exhaust will have to be modified for LT's to work on an LT1/4. I have the 02 bung welded and will put them in the collectors.
Old Feb 8, 2007 | 11:29 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Just a q. to ck: in NJ, can you get past inspection with no cats?
Old Feb 9, 2007 | 04:04 PM
ubnpast's Avatar
ubnpast
If you happen to know certain people
Old Feb 9, 2007 | 04:06 PM
ubnpast's Avatar
ubnpast
cheetah: Will the em lt's need no modifications to work on my lt4?
Old Feb 10, 2007 | 01:15 AM
A95Y's Avatar
A95Y
The C1180 looks like it'll bolt right up. You will still need exhaust (and cats). Those are nice looking headers. Looks like an excellent choice.
Old Feb 10, 2007 | 12:04 PM
Travis93's Avatar
Travis93
EM is having a group purchase now for $100 more than those Ebay ones and are made just for LT1/LT4 Corvette's.
Old Feb 10, 2007 | 12:44 PM
ubnpast's Avatar
ubnpast
Where would that be at, in the gb section?
Old Feb 10, 2007 | 01:23 PM
BADDUCK's Avatar
BADDUCK
Do a search it's a thread here.
Old Feb 10, 2007 | 08:47 PM
ubnpast's Avatar
ubnpast
I couldnt seem to find anything...
Old Feb 11, 2007 | 04:41 PM
clf93lt1's Avatar
clf93lt1
http://forums.corvetteforum.com/show....php?t=1617338
Old Feb 11, 2007 | 07:24 PM
ubnpast's Avatar
ubnpast
Thanks for the link!
To Hooker Headers
