95 will not start
Old Feb 9, 2007 | 12:07 AM
c4b4's Avatar
c4b4
6th Gear
Default 95 will not start
I have a 1995 LT1 that I am having a difficult time getting started. It was running fine, then I went to start it the next day, and nothing. My first thought was that the battery was dead, so I connected it to the charger. It then started and ran for 3 seconds and quit. Other symptoms include;
No interior lights when the door is opened, although I can switch on the interior lights, all other lights work fine.
The digital dash does not work.
Alarm system does not work including the keyless entry.
I checked the battery and connections, every fuse that I could find (by the door and under the hood), starter, transmission range switch, and numerous other electrical connections. I have not yet checked the ignition switch.
I am just about out of ideas and am almost ready to take it to the man and get this running again.
Old Feb 9, 2007 | 12:09 AM
RRT vette's Avatar
RRT vette
Did you replace the battery? If not, it would be a good place to start again.
Old Feb 9, 2007 | 12:11 AM
c4b4's Avatar
c4b4
6th Gear
The battery was replaced about a year ago. I had taken the battery into the local parts shop to have it tested, and all was fine.
Old Feb 9, 2007 | 12:15 AM
RRT vette's Avatar
RRT vette
Ok, if the battery is good...the next thing that comes to mind is the CCM.
Old Feb 9, 2007 | 12:24 AM
c4b4's Avatar
c4b4
6th Gear
And if it is the CCM then is it correct that I would have to take to the dealer for repairs?
Old Feb 9, 2007 | 12:42 AM
RRT vette's Avatar
RRT vette
I mentioned CCM, because I have had one go bad on me.
"No interior lights when the door is opened, although I can switch on the interior lights, all other lights work fine.
Alarm system does not work including the keyless entry."
That sound a lot like what mine did.
If you turn the key, does anything happen or is it dead as a door ****?
Old Feb 9, 2007 | 01:01 AM
c4b4's Avatar
c4b4
6th Gear
When I turn the key, nothing. Although occasionally it will start and run, for about three seconds. Once I get it started, it does not matter if I give it gas, or not.
Also, the check engine light is on, in addition to the Service ASR and ASR Off. I borrowed a scan tool to read the codes, and it came back that the vehicle is not responding.
Old Feb 9, 2007 | 08:52 AM
Tom Piper's Avatar
Tom Piper
http://www.corvetteactioncenter.com/....php?qstId=151
Tom Piper
Old Feb 9, 2007 | 09:43 AM
jfb's Avatar
jfb
Remove the battery cables (neg first), clean the cable lugs, bolts, and the battery posts and reconnect (neg last). You want your battery connections to be like your lover, bright and tight!
Old Feb 9, 2007 | 09:07 PM
c4b4's Avatar
c4b4
6th Gear
Yes. I checked the battery terminals out and used a litte steel wool in the process. I think that they are fine.
Old Feb 9, 2007 | 10:21 PM
pcolt94's Avatar
pcolt94
Do the head lights work OK? This would give indication of battery status.
I would check battery voltage with a meter, then you really know what is going on. If indeed the voltage is up at about 12 volts and car systems don’t work, you might look for a loose connection or something along those lines. Batteries can go bad at anytime, a year old is a possibility. I would say if your getting 10 volts or less at the battery terminals under a light load, all bets at off for other systems operating properly.
I would focus in getting the basic low level systems working first like lights and dash. The engine will probably run once you get the rest fixed.
Old Feb 27, 2007 | 11:51 PM
c4b4's Avatar
c4b4
6th Gear
It turned that the PKE module was bad. It not receiving the signal from the keyless entry which was preventing the car from starting. The part is on order, I should be back in business by the end of the week.
To 95 will not start
