drive shaft harmonic balancer
Old Feb 9, 2007 | 12:56 PM
jonrbrt's Avatar
jonrbrt
Default drive shaft harmonic balancer
I have a 91 Convertible and it sounded like the front driveshaft u joint was going out but on closer inspection I found out it's the Drive Shaft harmonic balancer (I didn't know I had one) Looks like the balancer has come apart or loose from the shaft. I've been told by too local mechanics I should just cut the balancer off and throw it away. Then drive it and if I don't feel any vibration just drive it until the u-joints which are good now go out and at that time, when replacing the ujoints have a new balancer put on. Is it a common practice to run without the balancer?
