temp sensor
Old Feb 8, 2007 | 05:34 PM
Jim D's Avatar
Jim D
Default temp sensor
If I pull the temp. sensor out of the head in my 87, how much coolant will I lose. Thanks Jim.
Old Feb 8, 2007 | 05:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will lose coolant down to that level; I would drain about a gallon of coolant first, then put a towel under that sensor before removing it.
Old Feb 8, 2007 | 06:09 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
When I pulled my fan switch on the drivers side I lost about 3 quarts. I caught it in a clean oil drain pan.
Old Feb 8, 2007 | 07:56 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
How fast are your hands. I'm thinking I could pull one and install another in less than 5 seconds, so I'm guessing 3 oz.
Be prepared
Old Feb 9, 2007 | 01:54 PM
RRT vette's Avatar
RRT vette
Be prepared
To temp sensor
