1985 vette
Old Feb 10, 2007 | 11:39 AM
robertmax's Avatar
robertmax
8th Gear
Default 1985 vette
i have a 85 vette that smokes from # 4,6, & ,8 WORSE WHEN THE MOTOR IS COLD.i SET ALL THE PLUGS AT .0045 I KNOW .0035 IS RECOMMEND.MY QUESTON IS CAN I PUT A DIFFERENT PLUG IN THE #' 4,6,AND 8. OR MAYBE CHANGE THE GAP. ANY HELP WOULD BE APPRICATED. THANKS,BOB
Old Feb 10, 2007 | 12:28 PM
rick lambert's Avatar
rick lambert
What color smoke, it could be the valve seals which is common, possibly a head gasket. Does the smoke show up on each start up? or does it get better after the engine has warmed up.Typically valve seals cause smoke on the start up. If I were you I'd make sure I don't have any coolant in the oil and if not I'd probably do a compression test. I really don't think going to a different plug will help.What did the old plugs look like?
Old Feb 10, 2007 | 04:16 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default smoke
how do you know it's 4,6,+8? don't you have a Y pipe and a single cat?
If the plugs are fouled, you probbly need new plug wires unless you have 225,000 miles.
Old Feb 10, 2007 | 04:39 PM
Bob CTS's Avatar
Bob CTS
Please tell us what color smoke, what about #2 since it seems the one side is giving problems, check to see if the injectors are leaking on those cylinders as well. Do the checks as mentioned above as well.
Old Feb 10, 2007 | 06:27 PM
RRT vette's Avatar
RRT vette
I wouldn't recomend it. Just use the stock plugs and the standard gap. More than likely, the plugs are not causing the problem unless they are toast.
Need more info.
Old Feb 10, 2007 | 06:45 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I don't think you can fix an engine problem by messing around with plug gap or heat range. At least I've never heard of that working. I would have a shop look at it if you aren't sure of what's happening.
Old Feb 10, 2007 | 07:08 PM
LD85's Avatar
LD85
Valve seals depending on the color of the smoke.
To 1985 vette
