Crankshaft question
Old Feb 11, 2007 | 03:34 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Default Crankshaft question
What is better, one piece or 2?
And what is a nodular crank?
Also, how much power can L83 stock pushrod's and lifters support?
Old Feb 11, 2007 | 08:47 PM
C4Techie's Avatar
C4Techie
If you have a 2 piece crankshaft, you'll have to have it welded back together. Not recommended.
Nodular is a type of cast iron. It is superior to grey iron commonly used in castings.
Old Feb 11, 2007 | 08:50 PM
Grease Monkey
So a nodular one piece would be good?
Old Feb 11, 2007 | 09:13 PM
Pete K's Avatar
Pete K
The better crank(1pc or 2 pc) is the one that fits your block. 86 and up blocks use 1 pc, 85 and older use 2 pcs. The terminology referrs to the crankshaft main seal.
Nodular is iron. As in cast iron. Also referred to as cast crank.
Stock lifters and pushrods can support a ton of power. If you put too much spring pressure to the lifters, you usually damage the cam before damaging the lifter.
C4Techie's Avatar
C4Techie
You might have trouble finding a SBC crank that isn't nodular iron.
I didn't see this the first go around. Lifters and push rods are unaffected by the power output of the engine. They could become over stressed by some of the other valve train components that are required to obtain certain power levels. Don't forget that a flat tappet must never be run on any other that the original lobe.
Old Feb 11, 2007 | 10:05 PM
Grease Monkey
Thanks.
To Crankshaft question
