i have notice that when i shut the car off after several sec coolant will come out from under the car for a couple of seconds then it stops,by driver side under the car by middle or rear of the engine my low coolant lite does come on i cant seem to see any leaks from the top of the engine hard to see under the car w/o a lift any suggestions were could the coolant be coming from around that area.
Does your 88 have the oil cooler, could be the lines, what about a freeze plug, it is kind of hard to tell, just got to lift it up and get under to look, but the above is a start.
