Remove a Broken Spark Plug
Old Feb 12, 2007 | 10:06 PM
Mav's Avatar
Mav
Default Remove a Broken Spark Plug
Well this sux. Any Ideas. I borrowed some bolt outs but the bolt out is to thick!! Know what I mean?
Tips or tricks?
Old Feb 12, 2007 | 10:34 PM
Bob CTS's Avatar
Bob CTS
That first pic looks like I can see the hex, or our my eyes failing it has been a long day. Looks like you just have to put the socket on if since it appears the porcelin broke.
Old Feb 12, 2007 | 10:35 PM
bogus's Avatar
bogus
sheared the bolt part off? damn.
I don't have any great suggestions... I would hit it with pb blaster to break whatever bond might exist.
Mav's Avatar
Mav
nah, unfortunetly(sp?) the hex came out in the socket!!
Old Feb 13, 2007 | 12:01 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Here's what I would likely do in this situation:
1) Remove the exhaust manifold to get more working room.
2) Weld a socket to the shell. I believe you can get a wire welder in there enough to make the weld.
3) Remove the plug.
a) If the socket breaks off the plug, weld it again.
Someone here posted that GM says NOT to use antiseize compound on the plug threads.
Maybe they should read this thread.
ALWAYS use antiseize on the plug threads and ALWAYS, ALWAYS use it on the plugs that go into an alumionum head.
It'll come out, but it's going to fight you first.
Old Feb 13, 2007 | 05:31 AM
willfromthehill's Avatar
willfromthehill
I just had the same exact thing happen to me two days ago. To get the plugs out, I started the car and the compression from the engine blew out the center. Then I just put an ez out in the hole and they came right out.
Old Feb 13, 2007 | 06:03 AM
Sam Lam's Avatar
Sam Lam
Damn!!! I have never encountered this problem before. I fully agree with vetnutjim on the use of the anti-sieze compound. When you get the broken plug out, would you post a picture of what is left of the plug? I am curious to see how this can happen
Old Feb 13, 2007 | 09:24 AM
rick lambert's Avatar
rick lambert
I'd spray it with PB and try the way willfromthehill did.
Old Feb 13, 2007 | 10:17 AM
Mav's Avatar
Mav
Pretty Wild Ideas. Will let you know which one works and will sure post pics of the aftermath.
Old Feb 13, 2007 | 10:59 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I had the exact same thing happen on my old Corolla. I ended up driving it to the Pep Boys shop and they removed it for me. PITA.
Old Feb 13, 2007 | 12:19 PM
kennedys22's Avatar
kennedys22
I have an idea that might work. In my younger days I had this happen to me. The mechanic helped me by using a squared sided chisel. We broke out the porcelin, tapped the chisel into the hole, and then we had flats to use on the chisel. A wrench on the chisel helped back it out. It was a trick I'll never forget. I think we removed the exhaust manifold but I can't remember. Good luck
To Remove a Broken Spark Plug
