Will these heads work???
Thanks so much for your help.
Semper Fi
The old parimeter bolt heads have the original style for the center bolts...
The later (86/or 87) have the new style, which puts the center 4 intake bolts at a 72º angle.
The 92-96 have an LT1 intake. If the car came factory with an LT4 (not sure if any did) it would be different as the bolt pattern is closer to vortec, and the ports are raised.
-- Joe
-- Joe
Also one last thing how hard would it be to just pull my old heads off and drop these in? Should I just go ahead and have them replace the timing chain as well? I know I'm going to be getting all new gaskets and the timing will need to be redone but other than that will the pushrods just stay in place so I can just pull the old heads off and drop these on??
Thanks everyone for the posts.
A greatful Marine
the ports are slightly different. (which is not way different). so who knows. *I* have never touched one.
I do know, when summit was selling the LT4 intakes, they also sold the LT4 heads - so I don't know if they were needed or not.
http://www.grandsportregistry.com/lt1vslt4.htm
http://www.lt1intake.com/files/faq.html
-- Joe
-- Joe
Wouldn't this increase be the same increase that is given with the 86L????? Aren't these the exact same heads they used on the 86 convertables???? And if I get a bump of a full point I'm still at 10.5:1 which isn't over the top by any means. What would I need to do to make it work. With new gaskets is this a weekend job that can be done by your average guys or is there anything special I need to know that than timing problems.
Thanks for all the help guys.
The CORVETTE heads from a CORVETTE have the same bolt pattern as a pre 1987 SBC head.
NON CORVETTE heads, aka truck, camaro, Z28 and others did change after 86 to a different angle on the 2 pairs of bolts around the crossover passage.
You do not need to slot these bolt holes on the intake if it is a corvette head. Unless you put a non corvette TPI intake, aka Camaro, Z28.
Most of the intakes made today have the slotted bolt holes and you should use a good flatwasher on these bolts to have good clamping from the bolts.
Compression wise, usually 10-12 cc will change the compression 1 point. 1 point higher in compression is generally good for around 3% horsepower increase, crankshaft.
Going to 1.6 RRs, with the 113s, should net you around 20-25 HP increase.
You still should not have a problem with a .041 head gasket, attention to static timing and good gasoline.
The 113 heads have changes which are beneficial to power.
LT1s are a different bear altogether, although they will bolt on a L98, you will have serious cooling problems and no way to hook up a t'stat and return hose without MAJOR mods to both the LT! heads and intake.
EGGSACTLY!!! I think that is what I said, above, several times.
