355 ci cammed??? Stock chip need help!
Not trying to hijack but I would love to keep the stock chip w/ my soon to be ported TPIS heads and intake. (355 w/ stock cam and 1.7 rr's)
Block
bored .030 decked .020
crank turned 10/10
Clevite 77 bearings
Speed pro hyper flat tops, -6cc valve reliefs, polished tops
polished stock rods with ARP bolts
cloyes true roller timing set
Comp cam CS XE262H-14 Lift In .464 Ex .470 Duration @50 In .218 Ex .224
Comp cams lifters
balanced on a Hines
felpro 1010 .039 head gaskets
10.5 static 8.5 dynamic compression
Heads #128
Port matched,valve pockets,ports and chambers ported and/or polished
Crane 1.6 roller rockers
ARP rocker studs
Crane stepped guide plates
Crane push rods
LT4 springs
Guides machined and bronze liners installed
Deck resurfaced
Stainless undercut valves
3 angle valve job
Felpro viton seals on all valves
Intake
Super ram, port matched top to bottom
52mm TB with air foil
Bosch 22lb injectors
Holley AFPR
No EGR
No AIR pump
Exhaust
Headman Elite long tubes with heated O2 in one and wideband in other
NO cats
Magnaflow catback
Now back to the originally scheduled program.....
Well hopefully it runs good without a tune/chip and hopefully its faster than what it was
it was stock with 208,XXX
