A question about trans. temp. sending unit.
The kit looks similar to this:
http://www.jegs.com/webapp/wcs/store...0002_752949_-1
You can see how the plug screws in, the sender is much longer but still is not past the end nut that is inside the pan.
way I could measure the trans. temp. and also use it as a drain plug.
Is there a decent way to plumb it in, in a better spot?
I do have a trans. cooler to install as well, so will be getting some
fittings for the radiator and ATF line. I was thinking to use a tee fitting
off the ATF return from the radiator and plumb the cooler into that.
plumbing a sender and/or an external cooler. (The cooler isn't necessary,
the sender could be installed alone with the hoses just there to
adapt the tee fitting into the OEM line.)
Looking for Transmission Cooling Pans
I expect that temperatures will vary according to where the sensor is
mounted. I have not sampled temps at different locations but my
vote is that the supply line to the cooler will register higher than the
fluid in the return line and the pan.
With the gauge in place, average temperatures for the location will
become apparent. When the gauge starts indicating higher temperatures,
this will be the sign to consider taking appropriate action.
Regarding the adapter/drain mentioned earlier. Is it really feasible to
mount this vertically in the bottom of the pan on a C4? I do not know
but I suspect the plug and sender would extend down and be vulnerable.
I think it could work as a sender adapter if mounted in a wall of the
pan (but it would not be completely useful as a drain.) Some thought
as to which wall (front/rear/side?) would ensure the least vulnerability
and best wire routing.
Incidently, there is a plug in the transmission case on the driver's
side above the shifter linkage. I believe it is 1/8" NPT and my
understanding is that it is a port for reading pressures.
I have seen sender installation tips online that suggest using this
port for the sender (and may have mentioned it in posts here in the
past). HOWEVER, THIS PORT TURNS 90º INSDE THE CASE AND
THERE IS ONLY A THIN WALL AT THE BEND. The depth of the port
is shallow enough that A SENDER COULD BOTTOM AT THE TURN AND
IF FORCED, CRACK THE CASE.
I considered a hose in the port and mounting the sender to a fitting
at the end of the short hose before I elected to tap into the cooler
lines.
pan line, run that to the cooler with hose, then back to the stock
return line with a flare to hose barb fitting.
more hose. Barb ends, clamps and hose will work for cooler plumbing.
been running at? I suspect I'll need to cover the cooler in winter.
priorities in 2006, I have no sensor results from events yet.
Perhaps plumbing so that the oil passes through the external cooler
first and then through the exchanger in the radiator might help during
colder periods?
Bernie
I elected to tap into the cooler lines using the approach mentioned
earlier because it seemed to be the least intrusive manner of collecting
trans temperature data.
The fittings have a cost but they can either be used for a cooler if one
proves necessary or moved to another more needy project in minutes,
leaving no trace on the current car.
Aside from cost and issues entailed in swapping, consider that a deeper
pan like the Derale also requires thought about whether it can coexist
with an OEM convertible X-brace or an after-market part like the
R-D Cross-Frame.
I got this gauge:
http://www.egauges.com/vdo_ind.asp?T...d&PN=A021E061Y
I plan to install it in the center air vent above the radio, and another gauge as well. I haven't decide yet witch other gauge would be best.
I run some HPDE days and also drag, I may need a fan on the cooler but am not sure yet.
- 2287 for 5/16" fittings and 1/2" NPT female sensor port
- 2286 for 3/8" fittings and 1/2" NPT female sensor port
However, the fittings supplied appear to be compression-type units.
These fittings together with the solid block adapter seem to mean that
the OEM lines need to be cut up.
