Melrose exhaust users
Another note. I never used the two rearmost pipes (left or right). Instead I connected the adapters that connected to the x-pipe directly to the stock 2.75" pipes where I cut them from the resonator. The way I did it I put everything together with clamps (you'll need an extra 3" clamp with that pass side adapter pipe cut and flared) tightened the whole thing up, then drove it to the muffler shop and had them perimeter weld everything except where the headers meet the adapter pipes.
Using everything stock behind the resonator allowed me to utilize the stock springed hanger from the differential on the existing tabs. And, I didn't use the hanger from the rear of the transmission since exhaust is so much lighter. The whole installation makes the exhaust much tighter to the bottom car compared to the stock exhaust. In fact ,I've never hit the exhaust as I did the stock exhaust (although I have hit the driver side header coming down a speed bump - it'll **** ya off). The only other thing I did was wrap the driver side adapter tube in header wrap because it just seemed to close to the body. That seems to help keep the cabin cooler too; no hot feet!
If you're wondering, the car sounds great with the stock mufflers; I couldn't be happier with the solid, throaty sound!
I was actually thinking of using their system too. But if I'm going to have to fab up or modify parts of the system, I might as well build it myself, and have my friend tig it up.
CONS:
The adapter pipes are made to be installed around the pan of an automatic transmission; so if you have a manual trans. (as I do), there are a lot of the extra bends.
The system is a bit more complex than I need because I don't use any cats. When cats are not used, extra pipes (cat eliminator pipes) and clamps are inclued with the system. I'd rather they'd extend the existing pipes instead of using the two cat eliminator pipes.
PROS:
I did like the fact that I could get the headers without AIR bungs which is very clean looking under the hood.
Mine is an auto with cats and due to fitment issues I would say get the headers and have the exhaust built, don't buy it with the Random exhaust pipes. More time was spent getting the Exhaust to work than it would have taken to build one.
The Melrose headers are A+ the Random exhaust gets an F
Did you have any clearance issues with yoru headers? I have TPIS and they rub slightly on the passenger side. I am concidering getting a set without Emissions hook up since I don't need them, and they have been blocked off.
How low do the Melrose hang?
This is definitely weird what is going on with the Random part of the system. I've put a couple systems on and have not had issues yet obviously others have.
The muffler end of the system is not something that will match up to everyones choice of mufflers. That's the one down side to the intent of the system because of all the different muffler choices out there.
Has anyone tried to loosen the motor mounts and tweak the engine a little? I'm wondering if there are some slight differences that end up being big changes further down the line. Just a thought.
Also, we new some mods would be needed around the mufflers but the pipes delivered ended up one third of the way under the spare tire and not in front of it. The only pipe not altered was the X pipe, cats and the drivers front pipe.
I cannot say for other models but if you have a C4 just stick with the headers, they are worth the money and pass on the Random pipes.
Their Instructions should read....Pipe bending and welding required!
Final Grade
Quality
headers- A+
exhaust- B+
Fit
headers- A-
exhaust- C+
Sound
A++
All in all I am very happy I purchased this system.
87' roadster. They where great on the phone and shipping real quick. The headers bolted in wiht no problems but did have some fit issue withthe extension on the dr's side (automatic) x-brace, called them on the phone and ended up with a conferance call for about an hour tried their suggestion for remedy and it made the pipe not fit at all. Called them the next available day and they sent new pipes FED-ex had them by 10:30 next day
. Ended up shimming the x-brace and put a slight bend in it on the drivers side and it bolt up with no problem then, might have lost about 1" of ground clearance (car sits low to begin with the wide rims). The rest of the system was quick and easy had to cut some off the cat elminators (too long). Went with some Ansa Mufflers first and they give me a resonace around 1200-1600RPM other wise quite. Had the exhaust guy order some SStips and made up some eliminators with a couple of crimps in them (chamber) and made sure they came out far enough behind the rear. He had a big grin along with me and the kid(17) nothing sounds better that a SBC with a good exhaust (and cam)
. Can't really tell if all the resonance is gone the weather has turn real crappy here and have it put up for the winter. Will be putting it on a dyno later with and with out the mufflers /elimantors, going to do an intake/injector change and ECM tune. But the guys at MELROSE where good guys to deal with straight-up
WRO87
PS went with JETHOT coating it really drop the temps under the hood and Stage 8 Bolts kinda PITA but work well no retourqe yet.
Late this summer had the ansa mufflers off and 21/2" eleminators with the SS megaphone tips. Went down to Festus Mo. for a tune on the ECM after putting 30# injectors and a custom TPI that not only cut up but custom runners( the old ones cut in half and welded up to have just two tubes per side. With the mufflers off and the tune it is great at idle can here the cam sounds like NASCAR. Really not too loud until you get on it
then all hell breaks loose
. When going down the hiway at 70 it is quite and reserved you can here the radio and talk (convert) but just wait until you pound it. Yea might be a little loud but hell I'm old. Going to put a couple more crimps in the pipe to see if it will quite a little more of might make up an insert ( made a couple for the kids Harley ).. One thing that was a real suprise the custom tune has made a BIG CHANGE in mileage (the tuner told to see if better). Look we have had it since new (now34k miles) and have never gotten anymore than 23-26MPG. Now that the top end work, the exhaust change and custom tune the mileage last fall was over 32MPG and running between 32-38 on the highway
and will be running it more this summer and will play with the exhaust a little like I said. I will drop a note as we see how the gas mileage goes. wro87
Last night I finally completed the system. Just for reference I have a ’91 vert. I bought the Melrose smooth flow system without air but with EGR. I am happy to report that the Melrose headers are very nice from both a fit and finish perspective. I would highly recommend the headers to anyone. The Random exhaust system was a joke to install. I had to abandon the first two pipes that connect to the headers and have an exhaust shop bend new ones. I also abandoned the L98 rear hanger system in favor of the LT1 style support system that hangs from the differential case. The LT1 hangers provide support for both sides of exhaust as opposed to just one side like the L98 hanger does. Today the exhaust looks nothing like what Melrose originally shipped me. I still have to work out the cross brace issues as I know there is interference and need to figure out just how much shimming will be required.
In summary, I would buy Melrose headers again, however I would highly recommend that everyone stay clear of pre-fab’d Random smooth flow system. I would also recommend that Melrose disassociate themselves from the Random components as those that don’t understand the difference between the two companies will eventually begin to associate the poor fit to Melrose thus hurting an otherwise highly credible business.
My two cents on the subject.
Chris
Chris
Unfortunately I feel it has come time for that to happen. From here forward we will be sending customers directly to Random or whoever they see fit for the post header C4 piping. In Random's defense the L98 stuff seems to install w/o a hitch, but we will not be stocking that either.
To those of you developing your own system with our headers please keep us up to date as to fit and progress. We are always open to new ideas.
On a different note - Pypes exhaust is developing some C4 stuff, and will be looking into their product when completed.
