Melrose exhaust users
Unfortunately I feel it has come time for that to happen. From here forward we will be sending customers directly to Random or whoever they see fit for the post header C4 piping. In Random's defense the L98 stuff seems to install w/o a hitch, but we will not be stocking that either.
To those of you developing your own system with our headers please keep us up to date as to fit and progress. We are always open to new ideas.
On a different note - Pypes exhaust is developing some C4 stuff, and will be looking into their product when completed.
Are you saying Randoms L98 system from the headers back installs w/o any problems but you are no longer offering it for sale! What if anything, are you going to package as a complete system for an '89 L98?
What are my other choices?
I would prefer to buy a complete system that bolts right up with no fitment issues. I've heard nothing but good things about your system, it seems the fitment issues are all with later model C4's with LT1 engines, is that correct?
Zbra, I think you should call Random again and see if they have any news for new.
Upside is I liked the 3"mandrill bent stainless, but all connections on mine are now cut and welded as all slip fits will start leaking.
The hanger system has yet to fail, and mseven's pipe fitment issues can be from any number of reasons. I realize we endorse Random's product be selling it, so I welcome any and all feedback. I am simply going off feedback from our customers, though we have indeed had fitment complaints from Random Tech's 92-96 system, we have not in regards to the 84-91 (excluding Mseven's). I have no apprehensions selling the pre '92 system. If you are interested in the 92-96 sytem however, I recommend talking to Random Tech in person.
The stock exhaust support that is mounted on the trans or even an LT one, will not fit a 3" tube (w/out some serious modding. Therfor, the entire weight of the system rests on that rubber strap and the rear muffler supports (I tried 2 new ones to no avail, one even broke sitting in the garage w/out driving the car!!). Because the entire weight of the system is one that rubber band alll the slip fits tried to tweak downward, and would not remain straight.
I went and had a exhaust freind of mine weld tabs for LT hangers (off the rear end) and a soild bar suspension mount for the c beam, and also weld most of the tubes (less the cats).
Mine was purchased directly from RT about 4 years ago when they first offered the L98 system (before your co. was involved in marketing the set-up).
The tubes and all bending looks great. (Regarding the "rubber band" hanger read the above).
Tis system was intended specifically for hooker headers w/flanges. I did call RT and they tried to help, but, the bottom line is the angle coming off the collecter extensions did not come back straight enough to get the x" on. Putting the cats there was the only way it would fit (as there was more room on the cat slip fit than on the x' which was a tight fit).
Furthermore, at the time the gentleman I spoke with told me this sytem was modeled on an 85 and he had no other way of testing on another year or car..........
NOW, that was then, hopefully they changed some of this stuff around. I paid approx. 1k (at the time) for all tubes and the hi-flo cats, less mufflers (no hangers and no band clamps).
You are welcome, I just wanted to make sure that no one (including yourself) took my post as being directed towards you or Melrose (simply one mans experience w/a product)
I think that more venders and mfgs. should take an active role with their products, like you are personally contributing.
Thanks,
Mick
I am glad you welcome the feedback, but I never blamed you, as you did not make the set-up.
I was going to buy the entire Melrose/Random system for my '89 coupe but if I'm reading what you say correctly the stock OEM exhaust hanger mounted to the C beam and the two rear muffler hangers are not enough to support the weight of the 3" Melrose /RT system.
The stock rubber band hanger is the weak link and also the lack of support under the actual rear end when using this system (drivers side if done their way, is only supported by the collector and the rear of the muffler). I also used the LT-1/4 hangers off the rear end (tabs were welded to the tubes for those) which also helps support the drivers side.
The new brace still uses the holes in the c beam, but the part is a 3/8" steel rod with an "L" at the top and straight at the bottom. The straight is welded to the tube, with a steel enclosed rubber suspension piece inside that bolts to the c-beam.
Before any others read this I don't want to give off the wrong idea. I think the tubes and all bending are excellent and the bright stainless looks great. My only contention is that the details of supporting this exhaust system in the car is somewhat lacking for the L98. Adding the extra support that I have done is not expensive, and anyone that can weld can do the "tabs" and the c beam hanger in about 20 minutes.
When looking at the complete system from a pic on Melrose's website (The full system; Melrose headers, back to RT collector connections, X-pipe into dual cats then to rear dog-leg pipes that are supposed to mount to OEM style 2 1/2" mufflers) I see a metal tab welded to the passenger side rear dog-leg pipe that looks to me as if it would mount to the OEM rubber strap hanger secured on the C-beam. Is that correct?
What you are saying is that this metal tab that appears to be supporting the entire weight of the exhaust system, is not strong enough?
I know there are also two rear muffler hangers that support each muffler behind that C-beam support. So in total there are three rear exhaust mounting points. If I'm reading your posts correctly you say you have changed the C-beam exhaust mount to make it stronger with an L-shaped piece of 3/8" rod. Was it stainless and TIG welded in place? How did you do this? Then you also welded a tab on the drivers side rear dog-leg tube to provide an additional mounting point. How did you mount this to the car?
Sorry for all the questions, and thanks for your reponses and any additional input.
Pics would be great!
LT-1/4 hangers (going through bottom bolts ont the diff.) w/tabs welded to the tubes:
steel rod pass.side support welded to the tube and new hanger on the c beam:
I think the underside of your car is the cleanest I've ever seen! Wow!
Are those LT-1 hangers OEM from a later model vette? And do they mount to existing bolts in the diff??
Why use an LT-1 hanger on the pass. side and also the fabed L-rod mounted to the C-beam? Do you need to support the exhaust in both places so close together on that side?
GM PART # 10157949, DESCRIPTION: HANGER (rear hanger)GM LIST: $12.87.
GM PART # 10258672, DESCRIPTION: HANGER (rear hanger)GM LIST: $13.57
these were the pn's and prices from 05 when I did this, hope they are the same. They use the existing stock bolts in the rear (will fit a dana 36 or 44), so there is no mod to install the hangers (just weld a tab on the tube).
I used both these and the rod ***., because the drivers side has only the LTX hangers and the muffler hanger to support the weight. With slip fit joints, jarring/bouncing, some motor twisting, etc., and w/no support is probably not the greatest idea...IMO.
Hope it all works out for you......let us know
