Pre-Cats
Old Oct 7, 2001 | 10:05 AM
MelloYellow87's Avatar
MelloYellow87
Default Pre-Cats
Hello,
How do you know if your pre-cats or main cat are failing... Is there anything to look for???
Thanks Joe D. :confused:
Old Oct 7, 2001 | 11:35 AM
traxx1's Avatar
traxx1
Default Re: Pre-Cats (MelloYellow87)
If your car idels ok but falls on its but when probably cats, a bad smell, probably cats, best bet is to get new y pipe minus cats and install a high performance cat, did mine and it passes Arizona emissions easly and there is a sotp differance also.
:jester :jester :jester
Old Oct 7, 2001 | 11:53 AM
95vettski's Avatar
95vettski
Default Re: Pre-Cats (traxx1)
If it smells like 'rotten eggs' that's a good indication. Also, you can try tapping the converter if you hear pieces moving around that's not good either.
Old Oct 7, 2001 | 11:55 AM
tsquare's Avatar
tsquare
You can hear a metallic rattle sound.
Old Oct 9, 2001 | 01:02 AM
Lexdog's Avatar
Lexdog
Traxx1,
What kind of Y pipe and cat did you put on your car and where did you get them? I was interested in doing that to my 91 and also putting on some Flow Masters on.
Old Oct 9, 2001 | 08:52 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Default Re: Pre-Cats (Lexdog)
Ecklers has the front 'y' minus the pre cats. It comes with the high performance main cat, stock number 34198. It fits 86- 91 and cost 249.99. I just put it on my 90. It was on my door step 3 days after I called them.
[Modified by joecaver, 6:53 AM 10/9/2001]
Old Oct 9, 2001 | 04:31 PM
Rick86's Avatar
Rick86
You can also take your car to a muffler shop and have them check the back pressure or if your a DIY guy then you can check back pressure by hooking up a pressure gauge to the bung where O2 sensor goes or you can check for good vacuum.
Old Oct 9, 2001 | 04:46 PM
ZylaRace's Avatar
ZylaRace
Default Re: Pre-Cats (Rick86)
When the engine won't rev,.... When the exhaust manifold (header) glows red,.. Least one of U cats is glogged.
You should be able to see light through the main cat.
You don't need precats to pass emissions.
Precats do little other than add weight and a fair amout of back pressure.
To Pre-Cats
