help a newbee with power door locks
Old Oct 7, 2001 | 10:28 AM
sail one's Avatar
sail one
Cruising
Default help a newbee with power door locks
hey guys. being the proud new owner of a '90 coupe, i was replacing the outer door weatherstripping when i arced the power door lock switch.
the pdl's no longer work from the door or the remote. i've checked all of the fuses and breakers in the fuse box. theyre all ok, but i can't positivly identify the pdl fuse.
where is the pdl fuse or breaker, or is it a fuseable link?
thanks for any help. this is a great forum.
nick :confused:
Old Oct 7, 2001 | 10:56 AM
Fang S-289's Avatar
Fang S-289
Default Re: help a newbee with power door locks (sail one)
I'm not sure if there is a fuseable link on a 90. However, it sounds like you may need to replace the power door lock switch it's self. My suggestion is to check that first. The arcing quite possibly fried the switch.
Old Oct 7, 2001 | 04:17 PM
cshuman's Avatar
cshuman
Default Re: help a newbee with power door locks (Fang S-289)
I have a 91 and did the same thing. Take the carpeted panel off that is under the passenger side glove box. There is a small fuse block there that will have the fuse you are looking for.
Old Oct 7, 2001 | 09:58 PM
sail one's Avatar
sail one
Cruising
Default Re: help a newbee with power door locks (cshuman)
thanks for the help guys.
i don't think it's the switch, cause it won't work with switch disconnected,
she's under cover now. i'll look for that fuse under the dash tomorrow.
i'll let you know.
thanks again
Old Oct 8, 2001 | 07:16 PM
sail one's Avatar
sail one
Cruising
cshuman shoots and scores.
thanks dude fuses were right there. replaced and click click click
thank you
nick :D
To help a newbee with power door locks
