Header selection
Old Feb 18, 2007 | 06:37 PM
black panther's Avatar
black panther
Default Header selection
I have a 1986 Corvette with the L98 TPI, I am currently trying to figure out what headers I should get for my car there are two different styles. One has all the emissions piping on the header and the other dosent will it effect the car if I go with the pair without the smog piping?
Old Feb 18, 2007 | 06:50 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It depends on where you live. It will affect the car if they won't let you drive it because you can't pass a visual inspection!
Old Feb 18, 2007 | 07:17 PM
black panther
no i dont have to worry about inspections im licensed it wont effect the way the engine runs if i eliminate the smog pipes?
Old Feb 18, 2007 | 07:21 PM
Kool88vette's Avatar
Kool88vette
I'm looking for headers that will pass a California smog. Where are the headers with the smog crap on them? Do they have a Carb number? Is it possible to make your stock headers flow better by porting?
Old Feb 18, 2007 | 07:26 PM
black panther
You can find the smog headers on summitracing.com
Corvette Kid
No. I'm sure some members who are more well-versed on the L98 will chime in and give you the details. I believe you have an EGR tube that will have to be dealt with too. But none of this, done correctly, will cause any driveability problems.
Kool88, unfortunately there are no long tubes with a carb number. And so they will not satisfy CA smog regulations. There are CA legal shorties for all C4s though.
Old Feb 18, 2007 | 07:34 PM
Lucky7's Avatar
Lucky7
If you have the iron heads, and aren't plannig to upgrade anytime soon you can use Hedman plain painted, or the ceramic coated Elites. But if you have any thing more the port inlets are too small. ASK ME HOW i KNOW. The good thing is, if you go with these, you just chop off the front cats to plumb them in. I believe that they can be ordered w/or without emission hookups.
Old Feb 18, 2007 | 07:35 PM
Kool88vette
I checked Summit racing and I can't find any California smog legal headers.
Old Feb 18, 2007 | 07:39 PM
vader86's Avatar
vader86
Originally Posted by Lucky7
If you have the iron heads, and aren't plannig to upgrade anytime soon.... But if you have any thing more the port inlets are too small. ASK ME HOW i KNOW.
It'll be fine.
My opinion the OPs question is on my site, basically you have to decide whether you want to keep anything with emissions, as well as install tips.
Old Feb 18, 2007 | 07:44 PM
Kool88vette
Will they increase HP over my stock headers?
Old Feb 18, 2007 | 07:46 PM
vader86's Avatar
vader86
Technically yes, but is 5-7hp worth the expense and effort to you?
Old Feb 18, 2007 | 08:02 PM
Kool88vette
If they are worth 7 hp I will pass. Thanks Vader.
Old Feb 19, 2007 | 08:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I'm non emission tested so I opted for the hedman Elites with no smog fittings. Easy tie in to the factory Y.
Old Feb 19, 2007 | 09:35 AM
Corvette Kid
This won't help those with factory shorties but for those whose C4s have manifolds, you might consider porting them. This was a very common practice when I was oval track racing, in the classes where headers weren't allowed. The hot set-up was the early Corvette center-dump manifolds which could be hogged out to a 3" outlet easily. You could even buy them from a specialty company that would actually split them in two, to do the most advantageous porting job possible, and then weld them back together! But anyhow, a good porting job was worth a nice increase in the mid and upper RPM ranges on a modified engine. I would think that the LT1 manifolds would be quite comparable to the old Corvette manifolds as a starting point, as they are known to flow pretty well already as manifolds go. This is something that most of you who cannot enjoy longtubes could do yourselves. And it would be a great alternative to the (mostly) over-priced shorties available.
To Header selection
