Iac?
Old Feb 18, 2007 | 07:33 PM
black panther's Avatar
black panther
Default Iac?
I recently replaced the IAC sensor in my 86' my service engine soon light remained on and it says there is still a problem with the IAC? anyone have any insight as to what the problem could be
Old Feb 18, 2007 | 08:57 PM
tequilaboy's Avatar
tequilaboy
Are you sure you mean IAC? Are you getting a code 35?
Err #35 is not normally supported in our ecms.
The IAC is the Idle Air Control, not a sensor. The Idle Air control will not set a fault when disconnected.
Re-check the code and clarify what you have replaced please.
Old Feb 19, 2007 | 09:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/No...it%20Check.pdf
To Iac?
