Last night on the way home from the Darrell Starbird National Rod & Custom show I noticed something flashing on and off periodically in the speedometer display on my 90 coupe. It looks like a code for something: 5y5. Has anyone else seen this or know what it is??? I was on cruise control running 75mph.
99% chance your battery is on the way out. The other 1% is if you have had the stereo head unit replaced.
I had the exact same symptoms, SYS would flash 2 or 3 times, then go back to normal. I had suspected the battery for quite some time, and when I finally replaced it, no more flashing SYS , and much faster engine crank during start.....
