Antenna replacement questions
I got the unit loose, but when I seperated the top half from the bottom half, one of the springs dislodged. While try to press it back into place it flew off and I can not find it.
So I ordered a new antenna unit today, but I have a couple of questions.
1. The two wires that attach to the top of the unit are short and I would like to extend them so that I can attach them while the unit is hanging lower to the floor. What connectors and gauge of wire do I use to do this?
2. The wire that runs from the radio to the antenna is not detachable from the antenna that I have now. How is this going to work?
Thx
The wires on the unit itself I believe are ground wires. It's difficult, but easier to do once the unit has been mounted.
I tied a string to the cable and wires so when you push the rubber plug through th ebody, it will be easier to retrieve to replace the new one.
