fuel pressure problems
Old Feb 21, 2007 | 05:59 PM
twin540's Avatar
twin540
Default fuel pressure problems
just installed an aftermarker fuel pump . presure goes to zero after i turn off the vehicle. any advise of what i might of done wong.
Old Feb 21, 2007 | 08:28 PM
lead foot 85 vet's Avatar
lead foot 85 vet
there is a check valve which is part of the fuel pump system in the tank .......if you can have someone block the return line at the fuel tank using vise grips on the rubber line above the fuel tank right after shutting off the ignition...............if thats not it....maybe pressure regulator or leaking injectors.
