Just had my car scanned. It has a miss and I've been having an overheating problem. Just replaced wires, plugs and Opti, last summer. 1st off the scan showed bad O2 sensor on bank 2 after cat and cylinder 3 miss firing. They changed the fuel filter because I thought it was time ( can't hurt). Then they pressure tested the coolant system because I thought it had been sucking air in during cool down. Sure enough the water pump is leaking.
They suggested that I have the Injectors cleaned. That maybe the problem or it could be the water pump leaking on the opti. Any suggestions? Should I let them clean them for $46.00 or put something in the tank and let it clean itself?
From: One day you're a Comet...the next day you're dust... Arkansas
If you are talking about dealer injector service save your money. Why not go to an electric water pump. Many claim 6 to 8 HP gains. Then see how it runs. You can try a bottle of injector cleaner. I use STP black bottle in my Jeeps every oil change. Never had to EVER service injectors.
