Fogging Windshield / Vacuum Leak
Old Feb 24, 2007 | 12:24 PM
Corvette Chris's Avatar
Corvette Chris
Default Fogging Windshield / Vacuum Leak
Toward the end of the season, I started having a problem with my windshield fogging up on occasion. I could barely see a little puff of air coming out of the vents, and then it would start fogging up. I thought about the heater core, but everything is nice and dry. I'm not losing any coolant that I can remember, and I check it pretty religiously.
On a potentially related note, at the beginning of the year, I couldn't get full force out of the vents for both A/C and heat. Which leads me to solving a bit of a vacuum leak in the system because it's not opening the doors all the way.
Could both of these problems be related?
Old Feb 24, 2007 | 12:39 PM
SunCr's Avatar
SunCr
Could be - you didn't post what Year, but find the HVAC vacuum source in the engine compartment and follow it to a 3 way cylindrical check valve - under or near the left fuel rail cover on the LT motors. Near the left side of the Distributor on the L98. That valve often breaks with age.
A small amount of Defrost is the Default with GM a/c. A leaking evaporator core can lead to fog though you can also get frost as a refrigerant at normal atmosphere's is about 32 below. If your a/c isn't blowing as cold as it once was, stop by an a/c shop and have them stick an electronic leak detector in your vents. A lot won't charge you anything since it takes all of 2 minutes.
Old Feb 24, 2007 | 12:48 PM
Corvette Chris
Sorry about that, it's an '86.
Thanks for your reply.
Old Feb 24, 2007 | 01:47 PM
jhammons01's Avatar
jhammons01
nice reply
any valve location advice for an '84?
Old Feb 24, 2007 | 02:12 PM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
A classic sympton of leaking heater core. Have you felt the floor area on passenger side to make sure it isn't wet.
Old Feb 24, 2007 | 02:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Depending on the size of leak, the floor may not get wet as GM added a nice piece of foam to the foot well panel. Hello Mr. Sponge
Oh, and if you don't wash that panel, your vette will smell like anti-freeze for a long time. Ask me how I know
Old Feb 24, 2007 | 04:19 PM
Corvette Chris
Thats exactly what I was afraid of...
To Fogging Windshield / Vacuum Leak
